Question about HP Deskjet 2460 InkJet Printer
Blinking power light
My printer's power light keeps blinking when the power is pluged, and i cant print
  • 530 Answers
Friend, the problem are the following 1. be sure it has enough ink to print 2. the ink was not properly misplaced 3. there was something stuck on the printer roller 4. check the connection properly or if not reinstall the software driver and if stil not. you need to reset the factory memory through CSS utility.com
Posted on Jul 17, 2009
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
May 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Printer is not printing but power light is blinking
Try to restart computer first then printer.If not help reinstall the drivers.
Oct 22, 2009 | HP Deskjet D2360 InkJet Printer
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
GREEN LIGHT KEEPS BLINKING PRINTER DON'T PRINT
hi rudy, thank you for using fixya.
when you said a green light was blinking was it the power light or another green light on the printer?
i strongly suggest that you refer to these links to have it fixed if it is a blinking power light.
For instructions on how to clean the ink cartridges: http://www.fixyourownprinter.com/forums/printer/26642.
For a diagnostic procedure: http://www.annoyances.org/exec/forum/winxp/1073811565
For instructions on how to un-install and re-install the print drivers and other Lexmark software problems: http://www.techspot.com/vb/archive/index/t-10556.html
otherwise, we are looking forward to your reply.
regards,
voodoo
Apr 14, 2009 | Computers & Internet
Printer light keeps blinking after being pluged in
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. We will replace the printer, only if it is under warranty.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Apr 08, 2009 | Lexmark X6150 All-In-One InkJet Printer
Blinking Light with no cartridge problems
I believe this is normal with HP deskjets. I have a different model but HP deskjet 3740, which also gives a blinking light when there is a pending print job and or printer has run out of paper. I usually get rid of this problem by putting some paper and most importantly removing and re-plugging the printer power cord (which does a basic power reset on the printer and causes a refresh of pending print jobs). I hope this works for you too.
Jan 27, 2009 | HP DeskJet D1460 InkJet Printer
Power light keeps blinking and will not print
Just keep pressed the power light button until the light goes off.
Dec 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Cant print. the tear like button is blinking
I have a 6940 color printer and I am assuming the 'tear' buttons are the same. If so, it is an out of toner indicator.
Dec 05, 2008 | HP DeskJet 5650 InkJet Printer
On off light keeps blinking
try the following:
1. restart the printer spool service in by going into the services applet in the administrative tools section of control pannel
2. check if there's an updated driver for your printer:
uninstall the old driver and printer, reinstall the new driver and printer then test
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&rule=8638&product=303753&
(copy the entire link in the browser address box and hit enter)
post your findings!
Dec 01, 2008 | HP Photosmart 2410 All-In-One InkJet...
HP Deskjet 2460 InkJet Printer Logo
302 people viewed this question
Seeker5211
Seeker5211
