Question about Hunter Ceiling Fan Control Switch
The middle speed on my 11 year old Hunter ceiling fan no longer works right. High speed and low speed seem fine, but the middle speed seems stuck on low. Because of this situation, I replaced all the capacitors and the switch, but the problem remains. What do you recommend?
  • 34 Answers
I think it was becuase of the incorrect wiring. Call an electriction to fix it.
Posted on Jul 01, 2010
Replace the motor
Posted on Jul 17, 2009
HUNTER FAN PART # 85095-1
Either need new transmitter or receiver or both. Call 1-888-830-1326 to order parts.
Jan 07, 2013 | Hunter (25417) Ceiling Fan
I have a 52" hunter ceiling fan. It is 10 years old. Only the high speed works now. I small controller in which the switch is connected to seems burnt. It is puffed on one side and hard carbon on the...
mcdevito75 here, You can check with any store that carries Ceiling fans for replacement parts, and contact info, you can check online at Hunter fans.com hope this helps.
Aug 05, 2010 | Hunter (25417) Ceiling Fan
Our hunter fan won't work on high speed any longer, low and medium speed work fine, when clicked on high - it only goes at medium
Sounds like the variable speed switch may be worn out.
You should be able to purchase replacement switch at the local home depot- type store in the electrical supplies.
Trying to get an exact match to replace may be a bit difficult, but a similar 3 speed switch should work just fine.
Jul 18, 2010 | Hunter Ceiling Fan Control Switch
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a hunter ceiling fan its about 20 years old. my problem is the remote will not work the fan. when i have the fan set on high speed the remote will only work the high and when i set the the fan on...
I'm sure you put fresh batteries in the remote...right? Most of the time you can correct remote problems by carefully taking the remote apart and cleaning all the contact points with a pencil eraser.
Jul 26, 2009 | Hunter 21564 The Brunswick Bronze Ceiling...
Our Hunter fan speed controller is not working. When we press high, it goes on high speed. When we press medium, it goes off. When we press low, it goes on high speed. When we press off, it goes off. Can...
Hunter's remote systems are notorious for failures. We replaced ours before the fan was one year old, and then it did it again within a year after that. The warranty, of course was on the ORIGINAL part, not the new part, so Hunter will never help you out, even though their remote receivers (the part in the fan) are junk!
Jun 30, 2009 | Hunter Ceiling Fan Remote Receiver...
Fan stuck on LOW speed
It seems to me you have a faulty switch or the internal wiring is wrong. You can access the switch from the bottom of the fanwhere the light kit is connected. the wiring could have gotten mixed up when the light kit was installed.
Jun 22, 2009 | Hunter (25417) Ceiling Fan
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Not working
How old is it? If it is more than a couple of years old, the motor windings for highest speed probably failed. They can not be repaired as cheaply as buying a new fan.
Jul 18, 2008 | Hunter 28096 Westminster 52" Ceiling Fan...
Dryers Logo
525 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
