Question about Mitsubishi Televison & Video
We have an old Mitsubushi VS-5041 50" projection set in a coin op video game. It use to turn on when the game was powered up, now it has to be turned on manually. Can you tell us how to program the set so it comes on with power up (like a computer monitor). Thanks! Gordie
  • 3,741 Answers
Mitsubishi leads the industry with three rear HDMI 1.3 inputs and two rear component inputs for maximum HD connectivity. Both a front HDMI 1.3 input and a front component video input allow you to easily connect your favorite HD game system. check out your video game wires. -------------- Two HDMI inputs and two FireWire (IEEE 1394) ports are on tap for compatible sources. There are also two component-video inputs, two A/V inputs with S-Video, and two DVI stereo audio inputs for folks wanting to adapt a DVI source device to the HDMI input. Rounding out the connectivity on the rear panel is one set of A/V outputs with composite video, a pair of RF antenna/cable inputs, and a coaxial digital audio output. For gamers and camcorder users, there is a set of front-panel A/V inputs with S-Video on the lower-left front of the set. you will have to check out this front pannel av inputs wires.as this are eitther loose or not supporting and needs replacement. if the wires are faulty you can get it at www.bestbuy.com thanks.please do rate the solution.thank you for using fixya.keepupdated.
Posted on Jul 17, 2009
Galaga/ms. pacman arcade game won't power up, no response period, service number on the back has been disconnected, who can I call for service?
Look up your local coin op amusements vendors that provide equipment to local bars etc, They may be helpfull as they deal in these repairs everyday.
Dec 30, 2009 | Namco Ms. Pacman Galaga Cocktail Video...
TV turns off
There is an issue with your Processing Board or a power supply. Either one you will need to get the unit in for repair or have a servicer come to the house to see what the issue is. I would call around and get some price quotes on what the charges for repair are. A good shop will do this for you.
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
Mitsubushi VS-5043 Rear Projection,,, Replaced 3 Converrence IC's. Recovered green color. Red color is bowed. Cannot move red crosshais in convergence set up. Is their a way to reset? Could something else...
There are a few low value 1-watt flameproof resistors in the convergence yoke circuits. They typically range from 1 to 3 ohms. An open resistor will cause the respective color to be non-responsive. Also chack that you have the convergence yokes re-connected to the correct connectors on the board.
Nov 10, 2009 | Mitsubishi VS-5043 50" Rear Projection...
I have a coin op dryer modle cem2760kq0 i put im a new timer in but it dose not stop runing?
mechanical coin op timers come without the shut off cam installed
there are slots around the edge corresponding to different times, that take a pin cam. the pin cam is in the box for the installer to insert to the owners specification, between 24 and 60 minutes in 6 minute intervals usually, hope you retained the packaging, or the old timer which should have its cam pin still in it
electronic coin op timers have to be programmed
Aug 28, 2008 | Whirlpool Dryers
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Jan 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsu. VS-50707 problems
12 = No error detected, check power supply.
check all your voltage coming out of the power supply and check the fuses.
Dec 10, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50603, input is gone
happened to me also. Go to the menu, select setting, thrn av (home theater) and see if "locked to input 1" is "on". Mine was. then I set it to "off" and everyting works great
Dec 06, 2007 | Mitsubishi VS-50603 50" Rear Projection...
No power to hitachi projection tv in a coin operated game
the tube need high voltage to light up.but when used in a arcade game its pretty much just a monitor and need to make sure video is getting to the video circuits ,tvs have a OSD on screen display that offers information about the menu like brightness etc
Does the OSD show?
Can you hear high voltage?
Odds are if no picture then no high voltage if thats the case you need to troubleshoot the circuits and need a schematic and a voltmeter.Good Luck!
Oct 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
