1999 dodge cummins 2500 front axel seals
you need to pull off wheels,brakes, rotor /unit hub bearing, both axles and intermediate shaft, as well as the vac disconnec ton the front axle tube. if only the right side leaks then only then only pull the right axle and intermediate shaft and vac disco. it is a trick with a miller tool to replace the seal. the left side seal is inside the diff and the carrier has to come out to replace it. pete
