My hotpoint wma46 is stopping dead towards the end of thecycle so is not doing any fast spin
    Sniper:
  • 57 Answers
I work on washers and driers alot so maybe I can help.
From what you say, it sounds like this machine is going into a spin cycle (at least for a bit).
The probable repair needed is a inexpensive one although not always easy to do.
Anytime you work on an electrical appliance, make sure it is unplugged to prevent injury.
Remove the front cover using a flat screwdriver. There are two "clips" at the top about 2 inches from sides - (slide the tip of the screwdriver in finding the clip and pull out on the cover).
Once opened, at the bottom of the carriage you will see the motor and pulley system.
You will need to check the tightness of the belt. It should be fairly tight to prevent slippage.
If you see black dust looking stuff all around that area, then the belt has been slipping and is damaged. It should be replaced.
The motor has 4 (7/16") nuts at the bottom and the motor slides for adjustment of this belt.
Note: If you see grease flung in the inside walls of the machine down low, then the transmission gearbox is leaking which will cause operation failure. This is a sign of excessive wear and you should consider replacement of the machine in the near future, as this grease can get inside the machine and contaminate your clothing.
If you find the belt tight and undamaged with no grease anywhere, then the repair gets harder and you may want to consider your repair options.
The transmission in this washer is designed having the motor run one direction for agitate cycle and then it reverses direction to make the spin cycle.
When it reverses, the transmission pulley (large pulley) slides in a plastic "grament or fulcrum" that pulls the transmission shaft down / out (changing gears, so to speak).
This transmission shaft will sometimes "get stuck" after it has aged and will not "change gears".
When this happens, the high speed spin cycle stops functioning as it should.
If your willing to do the work, the "fix" will cost nothing but your time and effort.
You must remove the carriage to where u can sit it up-side-down on a flat surface with the pulleys up.
On the transmission pulley center you will find a plastic snap on cover you need to remove.
Using a pipe wrench, get hold of the plastic "grament or fulcrum" and manually turn it to where it comes out. You may have to apply some force to get it to move.
Once it moves it will free up and start functioning correctly again. Spray (WD-40) lubricant and wet all moving parts inside pulley, then reassemble the washer.
Posted on Jul 25, 2009
Washing machine model Hotpoint WMA46 - G wash 3kg load. When on the spin cycle, the machine started rocking violently, such as with a very unbalanced load. I grabbed the front of the machine and leaned...
I think probably the problem was caused an out of balance load.
which would cause the problem you have experienced.
The door catch can be replaced, but it means taking the door apart to replace it, and you may possibly have to replace the door lock as well.
I think it is worth repairing, but you may possibly have to get an enginner to do it for you.
Jan 08, 2011 | Hotpoint WMA46 Front Load Washer
Very noisy when Hotpoint Aquarius WMA46 is on spin
It is the main drum bearings that is causing the noise.
There is no provision made for lubrication.
It can be done as a DIY fix, but it is a very involved repair, as it means having to remove the whole inner workings of the washer,
Not a task I would recommend unless you know what you are doing, and feel competent to tackle it.
Good luck.
Dec 05, 2009 | Hotpoint Washing Machines
No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Jun 02, 2009 | Hotpoint WMA46 Front Load Washer
Select a program , i makes the normal noise , but nothing happens
Hi did you find a solution? as mine has just started doing exactly the same!
May 15, 2009 | Hotpoint WMA46 Front Load Washer
My hotpoint aquaris machine is not engaging the fast spin function. When it comes to the fast spin in the cycle the machine goes dead. The machine was performing the fast spin until recently however the...
everything you have described points to a blocked pump,worth blowing down the clear pressure pipe from the switch end while your in there to make sure thats clear!
Jan 12, 2009 | Hotpoint First Edition FEW12 Front Load...
HOTPOINT WMA46 filter reconnect problem
Regardless of the filter not being back in properly, this would not stop the m/c spinning. Remove the filter, and check it again for blockage. Push the hose on as far as it will go, or it will leak
Try spin again
Make sure you have not disturbed any wires to the motor, if still no spin, then remove motor and check carbons in motor.
Plz rate this solution.
Thanks.
Dec 30, 2008 | Hotpoint WMA46 Front Load Washer
WMA46
check that the outflow pipe is not blocked. Turn off power supply get a bucket ready, disconnect the outflow pipe from the u-bend under the sink and check that it is not blocked.
Mar 15, 2008 | Hotpoint WMA46 Front Load Washer
Hotpoint Aquarius WMA46 front loader
I 've had this problem a few times with these machines.
Some solutions that have worked for me are.
1 change the motor.
2 change the wiring loom
3 change the board.
The most common one is the motor even when the it has decent brushes the motor just will not pick up speed on the spin cycle.
hope this helps.
Dec 14, 2007 | Hotpoint WMA46 Front Load Washer
Washing still wet - door won't open.
not a fault with washer. i guess you are plumbed into trap under sink. the spigot you fastened drain hose to is blanked off - there are various methods of doing this including have to saw off the end of the spigot with the bread knife. possible also a fault with pump or filter
Nov 16, 2006 | Hotpoint WMA46 Front Load Washer
Drum spins once and stops
Hi there i recondition hundreds of these machines a year and i can tell you that your problem is the module board which has short circuited due to a wiring problem or depending on the type of motor that was fitted. you looking at a lot of money there is no easy fix to this problem.
Oct 07, 2006 | Hotpoint WMA46 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
