Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
MY D522W20 SOUND WET OUT WITHOUT WARNUNG AND KNOW HAVE NO SOUND WHAT CAN I DO TO CORRECT THIS PROBLEM
  • 668 Answers
I would check to see if you have sound using a DVD or a VCR. If so it is the Cable Box or Satellite Receiver causing the problem. If you still don't , look on your on screen menu for the audio adjustments and see if the speakers have been turned off. Also see if you have speaker switch on the back of the unit.
Hope this helps,
Skyassoc
Posted on Jul 18, 2009
I have a Nissan hardbody 2.4i petrol the plugs are getting wet and it starts to misfire what could be the cause
It is a chicken and egg question - which came first, the wet plugs or the misfire?
Are the plugs wet with fuel or is it oil?
Are all the plugs equally wet?
If the ignition system is in good order and the correct spark plugs, correctly gapped and in good condition are fitted, it would be expected if the engine was receiving (moderately) too much fuel, it would keep running until the plugs were completely sooted, black and shorting out and unable to spark properly but at that moment the plugs would still be quite dry.
Persisting after this will of course cause wet plugs if the engine is still relatively cool but the sooty evidence of what has happened will still be there.
If the plugs are relatively clean but wet it is unlikely to be fuel as such large quantities that is would take to wet the plugs without any sooting it would be doubtful if the engine ran at all.
I hope I have provided you with food for thought. If you need to post again please provide accurate and detailed descriptions of the symptoms and what you have already checked.
Feb 26, 2017 | Nissan Cars & Trucks
My computer has no Audio and video driver
You need to know model of your PC to get a correct drivers, if it's noname PC then you need to know model of video and sound cards to get correct drivers, you can open case and read model on viceo and sound cards, if they integrated to motherboard then you just need to know(read) motherboard model, also you can try to get this information using software like EVEREST or AIDA. When you get correct models name of your vide, sound or motherboard, then just write each one plus "drivers" word in google search and I'm sure you can download them without any problems.
Nov 15, 2012 | Computers & Internet
Break noises (rubber on rubber sound)
Pull the wheels off and inspect the brakes.
Feb 28, 2017 | Cars & Trucks
I have a Craftsman wet dry vac with blower capability (22 L). While I was using it to **** up water, the water came out of the blower hose. Now I can't get it to work as a vacuum. What can I do to fix...
Most wet dry vacs have a ball float that blocks the vacuum when it is full of liquid. Yours sounds as if it is full or the ball has gotten stuck in the up, or blocking position.
Jul 04, 2017 | Craftsman Vacuums
Verry smokey than usual
make sure your oil level is correct and not diluted by fuel. Use the recommended viscosity oil that is ompatable with wet clutches. Motorcycle oil. Avoid high unloaded revs. reving without a load is hell on rings and rods. Good Luck, Ned
Sep 16, 2009 | 1984 Honda NS 250 R
1991 mercedes benz 300ce. When I start the car and buckle the seat belt or belts the warning buzzer comes on and off. I don't know if it is a seat belt problem or an ignition problem. I only have the car...
on the driver,s side under dash there is an audible relay called a seatbelt warnung relay. I would recommend replacing it because by just unplugging it you may experience interior lighting issues. It is a very common problem with that era of mercedes. If you remove the under dash you will be able to locate it by sound with the key on. Unplug it with the key off.
Apr 23, 2009 | 1991 Mercedes-Benz 300 Diesel
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
