Question about Telex SpinWise 7-824D (301689000) DVD±RW Burner
Trying to burn dvd. It keeps saying Target drive not ready
I have three dics duplicator. The second one will not burner. It keeps saying target source not ready. what is the problem? Can it be fix
  • 696 Answers
Hi, assuming the rest of the drives are working there are three probable issues.
1. The cabling for power or data is loose or faulty, check the cabling, remove and reseat it, then try again with new data cable and swap power connectors with one of the other drives. If the results do not vary it's not the cables, If the problem moves with the data cable but is not resolved by replacing the cable it is the logic board at fault.
2. Try cleaning the drive, do not use brush cleaners as they can damage the head, just used a compressed gas can or air compressor on less than 20lbs/in, if this does not work...
3. The second drive may be faulty, check with the manufacturer/manual. Many of these devices require a specific model or one of only a few models for compatibility, replac with an appropriate model.
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
The burning drives are not recognizing the blank media.Try using all of the duplicator bays by burning to another drive bay. If all other drives burn fine then the one drive may need to be replaced.Try a different blank CD or using a different brand. The most common fault for this message is a bad blank disk.Finally clean the drive bays by using compressed air to blow any dust out of the system.
Dec 18, 2013 | ProDuplicator Computers & Internet
The error message "Target drive not ready" indicates that there is a problem with the blank disc inside the writer drive(s) of the duplicator. In order to solve this problem, please insert brand-new blank media into the writer drive(s) and press the ENT/OK button twice on the duplicator. If you are still having problems, please feel free to contact us @ 888-686-8868 x208. Thank you for your inquiry and thank you for purchasing EZ Dupe products.
EZ Dupe Technical Support
Jan 09, 2011 | EZ Dupe EZDupe CoolCopyD5 DVD 1 to 5...
The controller only burns to 4 out of 5 drives and 1 of the 4 working frive keeps making burn errors. Is it time to install new firmware to fix this? or do i have to install new drives? Can i install...
Hi I have this problem with my systor 0-3 target duplicator, the one tray works fine, the middle one keeps making burn errors and the bottom one won't burn at all I can't seem to find a solution
Sep 20, 2010 | Vinpower 16x CD / DVD Duplicator with NEC...
What do you when it says target disck is not ready on a duplicator
Your disk *WITH* the data is the "source" disk.
Your "blank" disk is the "target" media.
Try a different "blank" disk.
If not any better, then take the unit to a computer technician, to trouble-shoot the hardware that is used to write onto the "target" media.
Apr 02, 2010 | EZ Dupe 1-Target CD/DVD Duplicator with...
My Teac 1x1 dvd/d11A/kit burner/Dvw/D11A: will not copy Dvd, keep getting the message: "target drive not ready". Unit copies cd's alright.
whatever software you are using to burn dvd;s, make sure the right burner drive is selected. if it is selected properly and still having an issue. that means the dvd writer is busted and can't detect a blank disc place into it. in that case, have it replaced.
Nov 06, 2009 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Target drive keeps saying not ready
May I suggerst you reseat all internal connections on your drive? (Power, IDE or what ever) Make sure you are grounded to the case while you do this and you have the power cord disconencted from the wall.
Close up everything and re-connect all the stuff you disconencted.
After you do that, remove the device via the device manager.
Reboot - let windows refind the device. Have the driver CD ready if applicable.
Let me know what happens.
a
Sep 21, 2009 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Acard 1 to 3 duplicator can't seemto get past the traget disc not ready
of course theres a problem but what are you doing with the thing? are you formaating the disk first to render the dvds in the target drives? are you using the right DVD like DVD+ DVD+- or Blueray? need more information to help you. and it the DVD you are copying has been redered on another machine it won't copy it anyway. You have to use the same machine to copy it as thats how they protect copy rights now days.
May 29, 2009 | Computers & Internet
Target Disc not Empty!!!
I have a DVD/CD duplcator, yes I can burn a CD, but when I try to burn a DVD I get this message TARGET DRIVE NOT READY, what can I do?
Nov 26, 2008 | Acard Technology (ARS-2030LD) DVD±RW...
Accutower duplicator
accutower won't burn cd it says "no clear cd'
Apr 08, 2008 | Tower ACCUTOWER CD "Music" 5 Writer...
Teac 1x1 dvd duplicator dvw-d11
This seems to be a memory/cache problem - increase (double) your cache size .....
Mar 19, 2008 | Computers & Internet
Telex SpinWise 7-824D (301689000) DVD±RW Burner Logo
820 people viewed this question
Top Telex Computers & Internet Experts
David Payne
David Payne
Are you a Telex Computer and Internet Expert? Answer questions, earn points and help others
