Question about Microsoft Xbox 360 Console
My xbox box has 3 red lights flashing... i know there are different types of error how do i know which on i have?
    Problem Solver:
  • 6 Answers
After turning it on, and seeing it display 3 red lights, hold the sync up button and tap eject.
The lights will change to a different pattern. This represents a number.
The number is four digits, so you'll have to hold sync and tap eject FOUR TIMES, remembering each pattern.
Pattern numbers are as follows:
4 red lights = 0
3 red lights = 3
2 red lights = 2
1 red lights = 1
Most common ones are 0020 and 0120.
Posted on Jul 17, 2009
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Red flashing light at front of x box
Any Issues: 3 red lights error 2 red light issues,Graphical error Xbox Guide has solution. Download
Mar 21, 2010 | Microsoft Xbox 360 Console
What is wrong with my xbox it says error 65?
Error 65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
Flashing red:
1.the av cable cannot be detected
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
2.general hardware failure
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
Feb 08, 2010 | Microsoft Xbox Console
My xbox360 will not stop flashing red
Sorry, only answer is to phone xbox and arrange to have repaired. Good news is its all free and should be back with you in 2 weeks.
Sep 20, 2009 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 1 red light
Section
4 is flashing red Means
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E64: (not yet known)
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: (not yet known)
E73: (not yet known)
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
--==SECONDARY ERROR CODES==-
  • Turn the xbox 360 on, and wait till the 3 red lights are flashing.
  • Press and hold the sync up button (the small white one), while holding that button press the eject button.
  • The LEDs will now blink the first number in the code (as described below).
  • Release the eject button and press it again.
  • The LEDs will now blink the second number of the code.
  • The LEDs will now blink the third number of the code.
  • The LEDs will now blink the forth number of the code.
  • The LEDs will go back to the 3 red flashing lights.
  • All four lights flashing - 0
  • One light flashing - 1
  • Two Lights flashing - 2
  • Three lights flashing - 3
0002 power supply problem
0003 (not yet known)
0010 over heating
0011 over heating
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 (not yet known)
0101 (not yet known)
0102 unknown error - literally means the console does not know what is wrong. Possibly a short or cold solder joint somewhere (2 reports of people repairing this, one was removing moisture build up inside the console, the other used a hot-air rework to reflow the BGA Ram chips)
0110 Memory Error / Memory Overheating
1003 Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
1010 Hard Drive Error, Can be caused buy a currupt or missing Eprom.
1013 (not yet known)
1020 (not yet known)
1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
1030 (not yet known)
if your console comes up with ANY OF THESE CODES CALL MICROSOFT and they will repair anything for free
Dec 17, 2008 | Microsoft Xbox 360 Console
3 red flashing lights on my 360 help please
moz-screenshot-8.pngmoz-screenshot-9.pngmoz-screenshot-10.pngmoz-screenshot-11.png3 Red light errors are common with XBOX consoles, and are proven to be fixable!
I run a repair shop and get atleast 1 - 2 consoles in a week with the same problems! and I fix 99% of the consoles with this problem using the XBOX360 Repair Guide, available on google for instant download. You can get your copy from here and fix all common probelms with XBOX console!
Oct 24, 2008 | Microsoft Xbox 360 Console
Exbox 360 4 red ligths
4 red light is a problem with your AV cable.
THINGS TO TRY
  1. Make sure that the AV cable is correctly connected to the xbox 360
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
    You can also check to see what the error code is yourself if your not sure whats wrong with it.
    To do this, you turn your x-box on, press the Connect button on the console itself and hold it in. Now press the DVD eject button to and look at the lights. it should be flashing 1 light, 2 lights, 3 lights, or 4 lights. grab a piece of paper and write down how many lights are showing. While still holding the connect button, press the eject button again. Write down how many lights are showing again. Then press eject again, and write it down. Then do it one more time and write it down. After you do this, then come back on fixya.com and let me know what error code it is.
    1 Red light = 1
    2 Red lights = 2
    3 Red lights = 3
    4 red lights = 0
    so an example of what you might write down would be:
    0
0
0
which would be 0001.
If you figure out the error, you can also visit the following website and determine what it is and if you can fix it yourself:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Feb 24, 2008 | Microsoft Xbox 360 Console
Xbox
Unplug Xbox then replug it.I know because it hapens when power flickers.
Sep 29, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
273 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
