Question about Harman Kardon AVR 235 Receiver
Connect speaker selector to reciever
How do i connect 4 way speaker selector to receiver .model 40-244 radio shack
  • 3 Answers
Re: connect speaker selector to reciever
Dear fellow stereo fans:
First, you connect the wires which would go to your speakers in th respective speaker a or speaker b out. Second, connect one pair of wires from the receiver to the speaker selector. I hope this is helpful.
Posted on Jan 08, 2009
0 characters
3 Points
How to connect Niles #SSVC-6 Speaker Selector to Yamaha RX-V671
Greg, It pretty basic hookup,Just hook it up to your speaker terminal on the reciever or amp.To the input of the (Speaker) Selector.
Oct 04, 2012 | Yamaha RX-V671
Show me a pictorial diagram of a dipole antenna connected to a stereo reciever
You didn't list your receiver model number, but here's a generic picture of how you would connect an indoor FM dipole antenna to a Kenwood receiver. These antennas should be available at most home improvement stores or from Radio Shack. They cost around $10.00, maybe less.
Depending on your model, you may have use some adapters. Ask the store staff for help.
Aug 18, 2012 | Kenwood Audio & Video Receivers
How do I connect my onkyo tx-sr705 to a pyle pro speaker selector? I am "not" using the onkyo for a surround sound, only for music with 3 pairs of speakers in different rooms. (CD, Sirrus...
Hi Mdensonjr, I see that this was posted in 2011 but well the speaker selector would be connected to the Front speaker terminals, Thanks, JT
May 29, 2011 | Onkyo TX-SR705 Receiver
Kenwood Receiver VR 806 turning off
Sounds like the music amplifier is different to the tuner audio amp. The music amplifier is now looking at an unbalanced impedance which is less than it should be. Therefore the output chip of the music amp has more current through it than it wants so it gets hot and shuts down.Put a four ohm wirewound resistor ( from Radio Shack ) in series with each surround speaker to reduce the current flow through the amplifier output.
Apr 09, 2010 | Kenwood VR-806 Receiver
Speaker compatibility ( Just got this new reciever with 120 volts power requirement of the receiver, but in the philippines voltage standard supply is 220. can i use 110 voltage supply instead? and I dnt...
The most likely answer is no. Unless the power transformer is of the multi tap type and has a voltage selector window on the back panel... Most speakers today have an impedance of 8 ohms. The impedance is all you need to worry about when matching speakers. You can fit 8 ohm speakers to a 4 ohm system, but you cannot fit 4 ohm speakers to an 8 ohm system. It would overload your oputput stages and cause them to fail. It's best to match 4 ohm with 4 ohm, 8 ohm with 8 ohms.etc.
Mar 19, 2010 | Audio & Video Receivers
My reciever is shutting down completley when i try to turn on the second zone. i tried rewiring it but it still does it could it be the reciever or do i just have the settings incorrect?
if the reciever shut down with zone 2 on, zone 2 volume at -3 and nothing connected to zone 2 it needs repair if not reconnect the speakers to zone 2 speaker connections and make sure you do not have more than 4 pair of speakers with impedence matching volume controls or a impedence matching speaker selector box
Jun 15, 2009 | Denon AVR-785 Receiver
Popping sound at random times out of my AV Reciever/Surround sound system when video is playing.
Clean and tighten all connections. Get a can of spray tuner and contact cleaner from Radio Shack to clean the volume and tone controls if you have access to the body of those controls. Some disassembly required. If this doesn't help, suspect a bad variable resistor in the amplifier circuit.
May 29, 2009 | Sony STR-V444ES Receiver
Accurian AVR 31-5048 6.1
I power on the reciever and then it reads PROTECTION and then powers off. I initially thought that I blew out the reciever but I was wondering if it was as simple as a fuse. I can locate the product manual for this reciever.
Oct 29, 2008 | Accurian AVR-5048 Receiver
Hook up problems
either cut an rca cable and splice it to the speaker wires (not easy because the rca cable is coax type or buy rca ends from radio shack and do a little soldering
Jan 02, 2008 | Sony STR-DE835 Receiver
Harman Kardon AVR 235 Receiver Logo
324 people viewed this question
Top Harman Kardon Audio & Video Receivers Experts
Electro Med Services...
Are you a Harman Kardon Audio and Video Receiver Expert? Answer questions, earn points and help others
