Question about HP Pavilion dv4000 Notebook
Keyboard on my HP DV4000 acts as if windows key permanently pressed. If I hit M it logs off windows etc. The weird thing is if someone takes control of my laptop remotely the same happens. Any ideas?
I have a Toshiba Satellite A215-S7462 and the keyboard is acting weird. when I type and press H key it automatically goes in front of the last alphabet i type and when I press down up and side arrow keys...
This is caused by a short in the keyboard. Either something was spilled into the keyboard, or it was hit by a hard object.
Search EBay! for a replacement keyboard. Most of the time you can find them for $35-$50 and have a professional install it for you.
Aug 25, 2011 | Toshiba Satellite A215-S7462 Laptop
Turn on wireless
To turn the wireless on on your laptop:
1. Click on Start. Type Mobility in the Search box. Hit the enter key.
2. In the Search results under Programs you will see Windows Mobility Center. Click on it to open it.
3. You will see a button under "Turn Wireless On"
4. Click on it to enable your wireless.
Another way using a keyboard shortcut: Press the fn and F2 keys at the same time.
I hope this helps you-Thanks for using Fix Ya.
May 02, 2011 | HP Pavilion dv4000 Notebook
Hello, I try to print screen but it seem not working.. My laptop is HP pavilion dv4 ans using windows 7. Nomen
When you hit the "PrtScn" key, your desktop or whatever you see on the screen will "Copy" that image into memory. To actually see this image open Paint (or an other photoeditor program) and hit "Ctrl+V" (Paste). Now you can see the image, save it, print it or whatever.
Aug 23, 2010 | HP Pavilion dv4000 Notebook
Will not load to login window
if you know that it has a recovery partition on the hdd try to reinstall the windows cause it sounds to me like a damaged windows.. to do that try to press F11 on start and see if it has a recovery partition to reinstall from ...if not try with a bootable windows disk ...
If the boot order is not set to boot from cd first and its is not asking to press any key to boot from cd ..than you should insert the disk and choose from pressing at start F12 ( or F10 ) the boot device you need..and continue the installing from the disk by pressing any key to boot from cd ..
In the other matter it seams that someone (probably the last guy that installed it ) messed around and inserted a Bios password to make sure you will call him again the next time it breaks..This matter is only avoidable by opening it and removing the Bios battery to default the Bios settings ..
Jun 28, 2010 | Compaq Presario M2000 Notebook
Exact same problem.
Same problem..
I got a Windows update and the keyboard started acting weird.
Do a system restore to an earlier date before the mishap.
Then update Windows again.. It should fix the problem..
Sep 11, 2009 | HP Pavilion dv4000 Notebook
Keyboard keys L/G/R acting weird
It sounds like the Windows is registering the "Windows Key" as being in the "Pressed" position. This is the key between control and alt on the left side of the keyboard. Press it a few times and see if that helps. If it does not it sounds like that key or the keyboard may need replacement.
May 20, 2009 | Compaq Presario 700 470024-192 Notebook
How to change windows password if i forget it
hi,
Press ctrl+Alt+Delete button twice to get "Log on to windows" screen. Now give "administrator" as user name and just Enter without typing password. your will be Logged in now.
Hope this Both videos will be so useful for you.
Thanks,
Appreciate to rate as "fixya"
Apr 23, 2009 | Intel Computers & Internet
Right arrow key permanently 'pressed' down
Only solution here is to unplug the keyboard from the mother board. Just take apart the case and look for the ribbon cable going from the keyboard to the motherboard, and take it out.
Please rate, thanks!
Apr 15, 2009 | Acer NSK8458AN Keyboard
Side key functions on HP#5189 keyboard
Left side keys - moon-hibernating mode, club+hp - takes you to hp internet club (lots of resources,free classes, etc on hp), globe spinning-takes you to internet-yourhomepage, envelope-takes you to windows email, magnifying glass- takes you to windows live search, ?-takes you to help
right side keys- arrowup1-opens disk drive, arrow up 2-opens 2nd disk drive if you have two, solid dot-opens dvd suite, arrows left-rewind, arrow right -fast forward slow, 2 arrows right-fast forward fast, and solid square -pause these are all media functions
I discovered all of this by taking a chance and pushing the key to see what happened. really wish they put a manual, or screen showing functions for the keyboard. hope this helps someone else!
Mar 26, 2009 | HP Computers & Internet
Viewsonic Tablet PC keyboard issue.
Try reseating the cable that connects the keyboard first.
If that doesnt help there may be liquid around the connector and it needs to be cleaned off to keep the circuit from shorting out. You will need to find someone with the appropriate chemicals and may have to take the laptop further apart to clean it all up.
This is why when anyone gets a liquid spill i recommend getting it torn down right away and cleaned up, as it can damage things you cant even see. If the liquid has been in there too long it may not be repairable.
Dec 21, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
81 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
