Question about Philips Televison & Video
Interference i have a 26inch phillips lcd tv with avertical band of interference on the screen it is thereall the time on any output any help would be great
  • 26 Answers
Hi there.
>Check your antenna - if you have a small bedroom TV set bring it front (or borrow one from a friend that has one) and plug the aerial in it. If picture has the same level of interference, it is the antenna. Outdoor antennas usually require professional servicing due to hazards associated.
>If the bedroom TV shows clear picture, next step is to remove the possibility that the TV set interferes itself - get a pair of plug-on ferrite cores (they look like a 1-inch long round barrel slashed in half until clipped on as one) and clip one on the power cord, as near the TV set as possible, and the other on the aerial cable, as near as possible to the tv set again. If problem persists post again.
Posted on Aug 06, 2009
For several months we would get bands of lines across our screen. We thought we were experiencing some kind of outside interference as it would come and go. Two days ago the bands began to cover most of...
You're verical output IC is dead, this might because of a leaky capacitor on that section which causes the lines across the screen.
The processor shuts down the unit automatically to avoid further damage to your tube.
Send it to repair shop to isolate the problem. This is fixable.
Thanks for using fixya.
Jan 18, 2011 | Hitachi Televison & Video
Transceiver signal interference
The FT-840 uses a die-cast RF power amp with thermally switched fan to ensure full power output (up to 100 watts). The digitally synthesized local signals ensure clean, low-noise transmitter output on all HF amateur band. There might be no AC line interference. it has strong Rf output. any AC line intersect does not affect its radio performance. Check and adjust RF power so to maintain proper output. some times more RF power generated at the output may cause interference. adjust Rf power..Even some unfiltered Noise getting the other end of the end may calso cause interference. Check for any Ripple voltages present at the output. Contact authorised service station for further Rectification. thank you shanth
Dec 23, 2007 | Computers & Internet
Phillips 28in wide screen tv. Picture OK through Sky, but has two moving distortions on ordinary aerial. Actual picture is good but the distortions moving up the screen make it very difficult to watch.
Even digital signals can be sensitive to electrical interference and using an antenna, you could be getting garbage from any nearby 'noisy' source. Something you might try is to temporarily switch off any electrical device in your home, one at a time and look for changes in the banding you have.
If the antenna you are using is outside (rooftop) and is rotor equipped, try changing the position to see if there is any increase or decrease of the problem. If an indoor antenna, rotate it slowly while watching the TV display for change. You may be able to determine the general direction of the source of interference. Some seemingly innocent devices that can cause problems; - Light dimmers/controllers - Poorly designed network routers - Cordless phones - Power supplies
Dec 01, 2010 | Philips Televison & Video
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080.
I assume your Misubishi is not close to anything electrical. However, it sounds like you have had an interference for some time. This will ineviteably cause the HDTV LCD to collapse. LCD's don't respond well close to heat. Is there a vent close? LCD's do well in a properly vented area but with all this said.......they will pick up interference from anything electrical. A few questions to ask ones self........are there any wireless devices or chargers close to the LCD? Might there be an oven, a/c unit or other wiring with 220 volts anywhere close to the LCD such as in the wall?
The Mitsubishi LT is a very reliable, multi component ready set that allows great viewing with surround sound. However, stop and think about this interference. It is not something in the unit. It is an interference. Look hard and when you've discovered it.....you won't believe how crystal clear this set will be.
Let me know what you find...Thanks for using Fixya and add any comments that may help us help you.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Sony Bravia with Phillps dvd player
The DVD player may have multiple output formats that can be displayed. Sounds like you have the composite output selected when you have the component output selected on the DVD player. Check the menu options on the DVD player and confirm they match the way you have the player connected
Aug 31, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
PHILLIPS PLASMA TV HAS BANDS OF LINES GOING THROUGH SCREEN
Usually ,by your description, when I ran into this it was caused by signal interference. Try playing a dvd or vhs. If problem goes away call your service provider(cable or sat.). If problem is still there remove rear cover and access boards. Look at inverter board where plug goes into it and you will see two capacitors. If discolored or misshaped, replace them. Or replace whole board. This solved over 3/4 of completed repairs on these for us. Good luck, Russmann.
May 30, 2008 | Televison & Video
Help
All lasma an lcd ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. There is a possibility that the screen is shot if the lines are very tiny, the black and white could just be adjustments, but the lines need to be taken care of first if they can,Good luck.
May 30, 2008 | RCA L26WD26D 26 in. LCD TV
Intermittent Defect on LCD TV
If new, you should not remove anything, just send back to store or Manufacturer
Mar 13, 2008 | Philips Magnavox 27MS343S 27" TV
Universal remote control for a toshiba comb tv vcr dvd
How Do I get my Menu button to work for a 26inch Toshiba Lcd flat screen Tv ?
Dec 23, 2007 | Televison & Video
Horizontal banding that looks like Interference
i would take this in for a service check could be issues that need resolving from a service standpoint not a simple driver or resolution fix
Dec 18, 2007 | Acer AL2216W LCD Monitor
Televison & Video Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
