Question about Dell Latitude D600 Notebook
HP DV2000 Black Screen
I had this happen twice to my unit and each was preceded with three beeps. I took it to a technician who told me he'll heat up the motherboard. There were a 3 or 4 similar units in his table with the same problem. The screen came back after the heating cure. The second time happened after 4 months and I had to take it for a third time within 2 weeks. This is bad. Just earlier today, I got it back from the shop and when I booted it up it, the familiar 3 beeps went again.I remember the technician say (on the 2nd visit) that it may also be with the battery. So, I removed my old battery and put on my spare battery and it worked. I am keeping my fingers crossed that it will continue to work. The last resort I was informed was to replace the motherboard.
What might be the cause of hp pavillion dv2000 not displaying on the screen at start up and giving 3 beeps, 1 long and 2 short, sometimes it boot but doesn't get to the desktop area?
1 long beep followed by two short beeps is usually indicative of a failed/failing display adapter. On something as.... rustic as your dv2000 it can be fixed.... but probably would see better value from just replacing the unit.
Oct 23, 2010 | Computers & Internet
Black screen on HP Pavilon dv2000. It does have the power from both ac adapter and battery as I can see all the lights on keyboard. I can hear the fan when press power button. Does not make any sound when...
Unplug the computer from the wall, hold the power button in for 1 minute. This will reset somehow the bios and remove any electricity left inside.If still doesnt work take a look to the cpu and heatsink
Jan 18, 2010 | HP Pavilion dv2000 Series Laptop Full...
Hp pavilion dv2000. . black screen error with
1) Run the memory test from bios
2) if it fails,remove the RAM and reinsart the ram
3) If the same issue then take out the ram and put it back by interchanging the slot of the ram. we need to check the ram one by one
use the 1st ram then check
if same issue
then check with another ram
issue should get resolved
4) if the same issue then the ram is gone bad
otherwise slot is gone bad
Dec 14, 2009 | HP Pavilion dv9000z Notebook
The screen on my hp pavillon dv2000 went totally black. Tried an external monitor, but nothing... still a black screen ! Help please
There are VGA port issue in the Motherboard .Pls repair it by vendor or connect any PCI gGAPHICS CARD FOR THE SAME.
Nov 18, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
HP pavillion dv2000 black screen with all lights on after the power is on the operating system didn''t load. It is only black screen.
There are many problems that can cause this. It can be the monitor itself, it can be bad RAM memory, faulty hard disk, corrupted windows install, etc. The only surefire way to pinpoint the problem and get it fixed will unfortunetly be to get it to your local technician and get it opened up.
Jul 07, 2009 | Dell Latitude D600 Notebook
HP pavilion dv2000 hangs with startup screen and when i do force shut down it gives beeps until i remove the battery and the the light is keep blinking on my laptop
hello..i think their is the problem hardware on the unit..try to remove the memory and try to clean or try to replace..thanks...and Good Luck..^_^
May 13, 2009 | Dell Latitude D600 Notebook
HP dv2000 gone dead
the problem occord when the battary charge full somtimes... try to switch on the laptop with battary power (if u getting the beep its k) wait for 10min and swith off the lap n turn it on.. this may work some laptops... when the battary get 100% charge the error beep will *** up... try 2 turn on the lap above 80%....
thanks
Mar 30, 2009 | HP Pavilion dv2000t Notebook
Hp pavilion dv2000 no lcd dispaly
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Sep 24, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
HP 1 long and 2 short beeps
I had the same problem. Turn on your laptop (dv2000) and let it do its thing with the black screen and One long and Two short beeps. Keep the laptop plugged in...Now here is where the "are you kidding me" part kicks in.
Wrap your laptop (while it's on) in a blanket and put it on a bed or a couch (where the laptop won't have room to circulate air beneath it). You must leave it wrapped in the blanket for about 30 minutes minimum, or wait an hour if possible.
Chances are, your laptop will get ver hot and shut itself down at some point before you come back in an hour. When the hour is up, try turning on your laptop again. Ideally, it should work and you now have a working laptop again.
I realize this sounds crazy, but I am typing this quick fix from my dv2000 after doing exactly what i just subscribed. I read it on some other forum when i was on my wife's pc. If this doesn't work the first time, try it one or two more times. This trick has something to do with getting a "broken" (?) connection between the video card and the motherboard soddering back together.
Hope this helps at least one of you. Good luck.
Jul 23, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
121 people viewed this question
Alun Cox
