Question about Sony Ericsson Cell Phones
Sony Ericksson Mobile Phone
The screen has gone white. I can call out and receive calls but there is only a white screen and nothing else.
  • 53 Answers
SOURCE: Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
Posted on Sep 09, 2007
SOURCE: sony ericsson w850i blank screen
jus flash it to a new fs and firmware............worked good for me
Posted on Aug 07, 2008
  • 2110 Answers
SOURCE: blank white screen
It seems to be ur lcd stops working..Take this to service center...
Posted on Nov 29, 2008
  • 6 Answers
SOURCE: Nokia N95 8Gb fell,screen is white.
The screen cable may have become loose or dislodged. You can find out how to replace the screen and also to check the cable here - http://spyda.vox.comlibraryphoto6a00d09e7ac027be2b00d41442e37f685e.html.
You can pick screens up on ebay too.
Posted on Apr 05, 2009
  • 624 Answers
SOURCE: My SE W610i works, but shows only white screen
Hello and Welcome to FixYa!
Woops, famous WSOD (White Screen of Death) this is all due to firmware bug you need to update the Software/Firmware of your phone, but no need to worry if you got the Data Cable of your mobile, you can solve this by yourself. I've done it many times for many SE Phones, with 100% success.
Ok, if you have got your cable, then proceed; I've attached the download link below, go there download the Update Utility, install it and then the wizard will guide you on how and when to connect your phone, its easy as 123. I am sure you will do it yourself, in case you are having any problems/questions don't forget to ask me. I'm here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Update Utility Download Link
Posted on Jul 31, 2010
Testimonial: "Thanks, helped much c(:"
SOURCE: my touch 3g has no service, my messages, my
My I phone 3G Want charge or will not hold a charge,I need all my contacts and I think I sync my contacts. I need help to find on my computer.
Posted on Mar 26, 2011
0 characters
1 Points
Sony ericksson unlock code
To get the unlock code for your Sony Ericson k750i mobile visit here you need to specify your country,IMEI number of your phone,Network provider to which it is locked.Then they deliver unlock code to you through mail.After getting the unlock code you can get the free unlocking instructions from here they will guide you to unlock your mobile.
Apr 03, 2013 | Sony Ericsson K750i Cellular Phone
How to unlock sony ericksson ST25i
Use unlock code to unlock your Sony Ericsson ST25i. Get the code from the site ,and unlock it using unlocking instructions which is given in the site itself.
Jan 21, 2013 | Sony Ericsson Mobile Phone Xperia U ST25i...
My k850i goes blank on boot
Dear amirul abdullah,
This problem most common due to when water goes into cell phone. Your k850i phone LCD screen have problem, you should go into Sony Ericsson service center to replace it.
Oct 30, 2012 | Sony Ericsson K850i Mobile Phone
How can i change themes in sony ericcson mobile phone....There are just 4 in built themes in it. Pls tell me from where can i download them.or give me a suitable suggestion...
you can use Google search to get new themes for you phone.
Just type in (themes for Sony Ericksson S312 ) and download all themes you would like to download by using the link on the page.
Take care.
Jun 16, 2010 | Sony Ericsson S312 Mobile Phone - Silver
White screen
you have accidently put it in dfu mode restore it in itunes or jailbreak it/re-jailbreak it
Sep 20, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
White screen
take the phone and have the lcd replaced on the phone from a mobile service center
Nov 08, 2008 | Motorola Mobility RAZR V3
White screen on sony ericsson z525a
try to flash your phone. take it to a service center and have it flashed. that would be the best solution for it.
May 19, 2008 | Sony Ericsson Z525a Cellular Phone
Sony ericksson k800i
Try having the phone reflash.
May 17, 2008 | Sony Ericsson K800i Cellular Phone
My screen won't work
i had the same problem before. theres nothing wrong with it, it just needs a new lcd screen. u can either fix it yourself or take it to a mobile repair shop.
Mar 29, 2008 | Sony Ericsson W850i Cellular Phone
Cell Phones Logo
23 people viewed this question
Top Sony Ericsson Cell Phones Experts
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
