Question about Garden
Changed primer on poulan 2175 and lines now the chansaw starts and runs and dies, acts like it is flooding
  • 3,600 Answers
Did you put the check valve in backwards? and did you reverse the fuel lines?
Posted on Jul 17, 2009
Poulan ym20cs won't stay running
Sounds like it needs carb adjusted and/or rebuilt.
Jun 24, 2014 | Poulan Garden
Machine continuiosly floods out
Sounds like to needle valve is sticking allowing extra fuel to continuously flood the carb. One easy quick fix is to add a product called Sea-foam to your gas tank and allow it to dissolve any gum deposits that have been deposited in your carb. Keep in mind that Ethanol gas will start to go bad in 30 days if you do not add a stabilizer (such as Sta-Bol Ethanol or similar). Best to never leave gas (stabilized or not) in your gas tank for more than 90 days.
Feb 24, 2014 | Motorcycles
Carburetor change
Primer bulbs pull fuel from the carb, into the bulb and dumps it back to the tank, if you have re connected the hoses to the primer the wrong way around it will try to force fuel into the carb and make it flood.
Jun 01, 2013 | Poulan Garden
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Poulan 21cc weedeater - starts but won't stay running. I've cleaned all fuel lines, cleaned plug and has plenty of gas - but still won't start. runs for 2 or 3 seconds and dies. appears to not be getting...
On these types of motors that could be the problem, another thing to check is the primer bulb. I have had a primer bulb that had a small crack in it which went undetected for a while. These types of motors do not have a fuel pump and they work on a siphon type mechanism, if there is an air leak dealing with the gas tank anywhere, that is your problem.
Aug 11, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan pro 625 series Will not start. I have changed the spark plug. Tested the plug for spark (yes) Checked the primer- works , sprayed starting fluid in spark plug hole and intake -nothing. it act like...
1st: stale fuel...won't burn...regardless of spark...
2nd: watch primer when it comes back up, it must "fill" with fuel...a tiny bubble is o.k. If not, carb replacement...
3rd: Flood to hell and back...remove the plug, pull 5 or 10 times to clear the gas...dry off plug...install...hold trigger wide open, and pull..NO PRIMER
if this works, go back and review starting procedure
8^)
Apr 17, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Model 2175 poulan - pump up primer bulb and it colapses. When i put fuel in head it runs till gone..
Change out the primer bulb and the small gas lines going to carb and primer. One of these has a small crack to let air get by and this is how you get a flat primer bulb. Pick the kit up at lowes for $6-8.
Feb 03, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Poulan Pro weed trimmer SM132 does not run. I replaced the primer bulb and spark plug and it ran fine for 10 minutes. Now it will only start with the choke on and dies immediately. It will not start...
The primer does require two lines attached as it is a Walbro style primer. All four SM132 models uses the WT628 Carb. Since the trimmer ran 10 minutes then you have got all the lines connected right. Mostly you got trash in your carb or it simply needs rebuilding as the diaphragm may have pin hole in it or the check valves are worn out. Depending on the age and use of your unit you may also have a sticking piston ring.
Aug 23, 2009 | Poulan Garden
I may have lines on Backwards??
filtered line from tank goes into top inlet at carb. bottom inlet receives line that goes to carb side of primer {draw side} 3rd line goes from push side of bulb bach to fuel tank.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
172 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
