Question about Sony Network Walkman NW-A3000 MP3 Player
Walkman won't charge ,plugged into computer for 1 hour, but comes up low battery and switches off
I pressed a pin into the" reset " on the bottom of walkman this seems to have done the trick
Posted on Jul 18, 2009
  • 3 Answers
You need either a powered USB hub (one with its own plug) i think or less likely a new battery (detailed replacement instructions can be found in the manual).
Posted on Jul 24, 2009
Westek TE06WHB Timer has been plugged in to charge for over 5 hours now and still now LCD display. It won't let me set the clock or program
Some of these timers use actual battery instead of rechargeable battery. Check back of timer for a battery door.
Press the reset button and see if this resolves the issue.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Check outlet polarity using circuit analyzer.
Plug timer into another outlet.
Turn on light switch controlling outlet.
See if a light works on same outlet.
Check circuit breaker.
This timer has 1 year warranty against defects in workmanship.
I suggest always buying timers at local store for ease of possible return.
Lowes and Target sell same/similar timer under different brand name. Buy new timer and return defect in new package.
Sep 05, 2012 | RTO Westek Weekly Digital Timer, White
Will not charge--will come on plugged into pc tower,but will not charge
it's charging when plugged into your pc, if it doesn't hold power well you may have a defective battery, plug it in and let it sit for 6-7 hours and see how long the battery holds out. if it doesn't work you have a bad battery.
Feb 15, 2011 | Sony Walkman NWZ-S616F MP3 Player
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
The screen has gone blank!!
Charge the Walkman fully. To charge the battery of the Walkman fully keep it plugged in to the Computer for 4 hours.
Reset the Walkman by pressing the RESET button that is located at the bottom.
You can use any sharp pointed object to press the reset button.
If the issue persists then Walkman may require service.
Jul 21, 2010 | Sony NWZ-E438F Digital Media Player
It won't play my music
If the issue still persists, then you may format the Walkman only using the FORMAT option in it.
Then transfer the audio files to the Walkman and check whether it works.
Make sure that you transfer the audio files that are supported by the Walkman.
Jul 20, 2010 | Sony NWZ-E436F MP3 Player
My player was turned out because of the low battery and now i can't see how the battery is charging...I can see only the name walkamn shining on the screen - this is it! (the player is connested with...
Hi lybastr,
I guess you have to let it charge awhile. When the battery gets too low, it might even refuse to go past the welcome screen. Let it charge for an hour or so. If the screen is still stuck on "walkman", then you might have a problem, but that's not common, so rest assured.
Jan 02, 2010 | Sony Walkman NWZA726 Digital Media Player
Nwz-s515 won`t charge
Check for a reset option somewhere in the software, if after reset (or if there is no reset option) it still does not charge then the battery has died. You can call Sony for repairs, it may be under warranty still. If it needs repair head over to Sony's website for repair at:
http://eservice.sony.com/webrma/web/index.do
Jun 25, 2009 | Sony NWZ-S615F Walkman Video MP3 Player
Can't charge my Sony NWZ-B135F Walkman
shut it off and try to reset it. Hopefully it works!!
Apr 23, 2009 | Audio Players & Recorders
Frozen screen
you should hit the reset button and that should do the trick and always make sure it's charged
Sep 13, 2008 | Sony NWZ-S616FRED Digital Media Player
Low Battery error message
I got mine brand new, it's never lasted more than five hours. Ripoff.
Jul 16, 2008 | Sony Network Walkman NW-A3000 MP3 Player
Sony Network Walkman NW-A3000 MP3 Player Logo
545 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
