Question about EnGenius ESR-1221 EXT Router
Having problems setting up the dynamic comcast cable.router puts out a signal but laptops do not communicate.can not use my internet on main computer cable modum icon shows 100 mbps but explorer wont bring up pages.
    Brigadier General:
  • 10,406 Answers
Call COMCAST. They can trouble-shoot from "their" end,
if you tell them that none of your computers get an IP-address.
Also, plug _one_ computer _directly_ into the COMCAST modem.
Can you web-surf with that configuration?
Posted on Jul 17, 2009
There is no internet connection to the laptop. The arris modem gives internet acess to the PC computer, though. The manual for the Airlink 101 router says to connect the router and MODEM to each other by a...
What you're missing is that ALL the PCs will be connecting THROUGH the router to the Modem. Unplug the PC network Cable from the modem, then plug a network cable from the router's INTERNET port into the modem (where you removed the PC's network cable). Now, plug the PC's network cable into one of the ports on the router (usually 4 or more, marked 1,2,3,4. Think of a Router as a "splitter". It connects to the Modem, then several devices connect to the Router, some of them by wire and some by Wi-Fi. So your desktop PC is connected by wire to the router and your laptop PC is probably connected by Wi-Fi (wire is an option, as well). The Router sorts out all those signals and communicates with the Modem. Sound reasonable?
May 02, 2017 | Arris Comcast Touchstone Telephony VOIP...
When i switch on my ADSL modem which is connected thro the dlink wireless router,my laptop shows"No internet access" in the task bar,but the signal zebra-band is visible-excellent signal...
Check your ip settings in your pc and make sure they are set to get dynamically. Also check under wireless lan settings that you have dynamic ip turned on.
Otherwise you will manually have to set your computer ip address to the range set in the router/modem
Oct 23, 2010 | D-Link Computers & Internet
I HAVE A NEW HP DESKTOP AND AN OLD LINKSSY WIRELESS G
Hi Vivian,
Chweck you cables and where they are conencted.
You will need to make sure that the Comcast modem is providing internet, you can do this by connecting your laptop to it using ethernet directly if it connects to the internet, that will be a good thing.
From your comcast Modem, the ethernet Cable should go to the linksys where it says "WAN". this should give you an internet connection and make your comcast modem communicate with your linksys Router.
Jul 22, 2010 | Linksys Wireless-G Broadband Router
Changed internet companies now router won't work
I'm sorry but I find your post a bit confusing. Do either of the computers get on the internet?
Changing internet providers is something done INSIDE the router. The cables are irrelevant.
Nov 10, 2009 | Computers & Internet
Can not get belkin router to hook up to comcast internet
hello. I will be more than glad to assist u on this concern.. ur using a comcast cable modem.. first.. connect ur computer directly to the router and perform a mac clone on the router. this will clone the mac address of ur network interface card and then use the dynamic settings
Aug 02, 2009 | Computers & Internet
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Please help...internet won't connect
You may be running into a problem of your ISP only allowing one computer on the internet. while the internet is on can you access the internet from the desktop comcast originally setup?  If so that is more then likely your problem.
I have comcast myself and they told me they do not allow home networks. I fixed that problem by using the mac address cloning feature in my router.
The setup cd is also junk, all you should really need to do is:
1. unplug modem, router, and turn off computers
2. Plug modem into router
3. Plug computers into router (don't worry about wireless right now)
4. Turn on modem, wait 20 seconds or so for lights to set,
5. Turn on router. again wait for lights to set
6. Turn on ONE computer that is hard wired into the router
7 Try to surf the net.
8. If successfull try to connect wireless computers (Without using cd) and see if they surf.
If not call comcast and see if your computers are trying to obtain real-world ip's instead of LAN ip's like they should.
If so, you'll need to enable DHCP on the router.
Jul 18, 2008 | Belkin (F5D7230-4) Router (587009)
How do i hook up a westell router to a moterola comcast modem?
Okay, well something is obviously wrong.
This is how it should be connected. Internet to modem, then with an Ethernet cable, connect the modem to the router (jack1) then with another Ethernet cable, connect the router (jack2) to the computer.
If you are still having problems, then contact your company to see if they could walk you through it, or if they needed to set things up.
Also, where are you connecting your laptop from? Is it very far from the router? Perhaps your router's signal strength isn't great enough? (This would mean getting a new, more powerful router.)
Jun 13, 2008 | Westell Wirespeed VersaLink...
Became new customer to comcast-got the bundle package, internet,phone,cable. Voice overlay modem to accomodate internet and phone lines. Did not use their wireless router-using exsiting router D-Link model...
Hi jad123,
I am sorry to learn about the problems you are experiencing with your service.
I will be happy to reach out to my contacts to assist you in resolving this issue. Please feel free to contact me so that I can get more information from you.
Thanks in advance!
Mark C.
Comcast Executive Offices
We_Can_Help@cable.comcast.com
Apr 10, 2008 | Computers & Internet
Internet will not connect through router.
Hello Orionj2
We can provide you with the best Comcast internet tech support, so if your Comcast internet is not working fine, then you just have to get in touch with support. Call us today and get internet related issues fixed.
Comcast Tech Support Internet Help Toll Free 1855 856 2653
Sep 20, 2007 | Belkin (F5D5231-4) Router
EnGenius ESR-1221 EXT Router Logo
358 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
