Question about Marantz SR8001
Shuts off !!
Brand new recever . it goes into protect mode & shuts off, all my speaker connection are okay , I cant figure out the problem!
Re: shuts off !! - Marantz SR8001 Audio & Video Receivers
Check your output stage
Posted on Nov 23, 2007
0 characters
3 Points
Unit goes into protection after a few seconds. Yamaha amp model no RXV 350
Disconnect all the speaker connections, and just switch the set ON. Even now the set goes to protection mode, the fault will be with its audio output section circuit. If it does not go to protection mode without speaker connections, check all the speakers. Connect on by one at a time; and switch ON the set; thus you can get the faulty speaker box.
Oct 07, 2014 | Audio & Video Receivers
Shut up stereo protect mode?
Protect mode is on because something in your speaker wiring is wrong, or you have a broken speaker, or it\'s too late and you already fried one or more of the amp\'s output transistors.
You gotta fix the problem. Not remove the safety guard and carry on with a busted machine.
Look for wires touching between the speaker terminals or on the backs of the speakers. If you done a half-ass job of wiring up then this is the most likely cause.
If you can\'t find bad/frayed wiring, then disconnect all the speakers out the back of the amp. Switch the amp on. Does it trip out? If no, that\'s good. Turn up the volume. Is it still okay? If yes, that\'s good. You haven\'t yet killed the output transistors. If it goes in to protect though, ut oh. It\'s Repair Shop Time.
If the amp is okay, then power off and add one speaker. Power on with the volume down. If it trips either at no volume or when you increase the sound, then you got a bad speaker and you just found it. Repeat the process, adding one speaker at a time. Make sure you put Vol to minimum and power off each time before adding the next speaker.
Sep 14, 2014 | Sherwood Rd-7405hdr 7.1-channel 70-watt...
Why does my new AVR X1000 keep going in protect mode
It only goes into protect mode usually when there are to manny speakers hooked up more then its can handle
Aug 01, 2014 | Denon AVR-X1000 5.1-Channel Network AV...
Receiver displays "protect" ...then shuts off
From what I have seen..........
Either you have a speaker that is shorting out, Try unplugging on speaker at a time and turning the unit on, and see if it goes out of protected mode. Keep the volume turned low while doing that. Just go by process of elimination. Or you can disconnect all speakers and see if you still get the error message. If not then connect 1 speaker at a time, if it goes in to protected mode while doing a speaker connection then you found the bad speaker.
Otherwise another thing I read a hard reset you should be able to do on the unit is hold down the power button until it display a message that says "Clear All", then hit enter or follow the directions it gives that should reset the alarm code if the receiver will allow it.
Hopefully one of those 2 things will clear your error........
Best I could find out
I would do the speaker test first, usually its a shorted speaker or wire
Aug 25, 2013 | Sony Audio & Video Receivers
Can't open,in protect mode
First disconnect all speakers from the unit and then try turning the unit on too see if it still goes to protect mode. Protect mode is a shut down feature that shuts down the unit because of a shorted speaker or speaker wires are touching each other. If the unit does not shut down after disconnecting all speakers then reconnect them one at a time while turing the unit on after each conncection until you find the shorted speaker. If it shuts down with no speakers attached to it then you have a internal problem with the amplifier section, probably a shorted output transistor in the Amp circuit or preamp circuit.
Jul 08, 2011 | Yamaha Audio & Video Receivers
Speakers work at low volume. Around -39 db, receiver shuts off.(protection mode) Tried moving speaker wires, alternating red and black. No go. When powered back up, display says ck sp wires. Once I...
Decibels correspond to the output voltage being sent to the speakers. In your case, the voltage is reached at -40dB is the threshold that causes whatever is happening to operate the receiver's protection circuit. You might have a bad speaker, with a voice coil that shorts at the higher voltage. Below that level it's okay, but at the magic point the insulation breaks down, and that's when the receiver sees trouble.
You might try connecting only one speaker at a time using a short length of wire other than your current ones. If the trouble occurs on one speaker only, you've found the culprit. If the receiver operates normally on each speaker, try reconnecting one speaker at a time to determine if one of the speaker wires may have a short somewhere. There might be a weak spot in the insulation, not causing any trouble until the voltage is high enough.
If the receiver still goes into protection with just one speaker, there's an internal problem. Some part in the amplifier may be breaking down at that voltage. Or a part value has changed, causing the protection circuit to kick in even though there's really nothing wrong. Bad solder connections may have developed. Unfortunately, this kind of problem usually needs the services of a shop with the equipment and circuit information to figure out what's happening. If you can find a Yamaha-authorized warranty servicer, they might already know some typical causes if they've seen units with the same trouble.
Try the speaker test first. Then let a shop tackle the receiver if it looks like that's where the fault is. Good luck and thanks for using Fixya!
Jun 03, 2011 | Yamaha HTR-5830 Receiver
When you are watching a movie and turn on system it goes into protection mode and shuts off. Also when you are listening to music when the volume reaches a certain level(not very loud) it goes into...
Loose speaker wire somewhere or heat.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 26, 2011 | Harman Kardon Audio & Video Receivers
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
How do i fix tis problem
First, disconnect all your speakers from the back of the unit. Then turn it back on, if it does not go into protection, turn it off and examine your speaker wires, look for frays that could touch the other binding post (most common problem). Then re connect speakers one by one; testing after each connection. If you get them all re connected and it still plays, you've solved the problem. If you get to a particular speaker and it cuts off, check the wire, then check the speaker. If theres nothing plainly visible, swap the speaker for one that is working and try again. If it still shorts, try a new wire. Beyond that, if it's still shorting, theres a problem internally with the receiver and it need to go to service. If you have all speakers disconnected and it still goes into protection, there is nothing you can do but get it serviced. There are no internal protection "fuses" Hope this helps
Jun 30, 2009 | Sony STR-DE597 Receiver
My samsung HT-TX75 keeps shutting off in a few minutes saying protection.
protection mode activated to protect from serious damage and please follow me.1-shut down your system2-make volume in low position3-remove all your connected speaker4-switch your system on and watch if it does not go to protect mode insert your speaker one by one until you find the bad one and change it and start with cable change first and then speaker itself-if it goes to protect mode you must call service center.
Jul 07, 2008 | Audio & Video Receivers
Marantz SR8001 Logo
383 people viewed this question
Top Marantz Audio & Video Receivers Experts
Pieter Vleeshouwers
Are you a Marantz Audio and Video Receiver Expert? Answer questions, earn points and help others
