Question about HP LaserJet 3055 All-In-One Printer
How refill toner? - HP LaserJet 3055 All-In-One Printer
  • 193 Answers
On what AiO?
if its a 12A...you have to remove screws, pull pins out. remove drum/waste unit, separate,
Posted on Jul 24, 2009
Compatible refil toner
There are a number of places that make remanufactured/refill toners for that printer. However you cannot use a refill toner for a "like" printer and expect it to work. The 5310 is the same printer as a Lexmark but you cannot use the Lexmark toner in a Dell; they have small ID chips in the toners that have to match make and model of printer plus the size of the cartridge. The 5310's do have 3 or 4 different page count refills. The refills are less expensive than the OEM's but they are still not cheap. OEM cartridge is about $399.00 and I just looked at Amazon and they have them for $190. When you compare prices, compare page count too.
Aug 01, 2015 | Dell 5310n Laser Printer
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
Brother dcp 7055 printer toner ended error
i haver Brother Laserjet DCP 7055 printer. Once i refilled its toner but now on 2nd time i refilled it the printer is gives an "Toner Ended" error & replace the toner message.... Pls help meto solve it... Thanks lucky bareilly
Jan 10, 2012 | Office Equipment & Supplies
Hp laserjet 1100 toner catridge refill?
Hi follow these steps..
1.Purchase a refill kit for your model of printer. It is important to purchase a refill kit designed for your specific model, since generic refill kits do not work well with HP printers. There are a number of places to buy these kits, but you must make sure you get the right kit for your printer model
2.Take the toner out of the printer and clean it carefully. Over time toner cartridges will accumulate paper dust, dried toner and other debris, and all of this must be cleaned away before the cartridge is refilled.
3.Flip the cover out of the way to expose the developer roller, then use a soft clean cloth to clean the roller. It is important to clean this roller before refilling the cartridge.
4.Make a small hole in the toner cartridge, using the instructions provided in the refill kit. It is important to follow the refill kit instructions carefully, since the toner refill process will vary from model to model.
5.Place the replacement toner in the hopper, then carefully pour it into the HP cartridge. Be careful not to spill any of the toner, and if you do spill the toner be sure to clean it up promptly. Reseal the hole you made after the cartridge has been refilled.
6.Sit the refilled HP cartridge on a clean flat surface and let it remain there for 20-30 minutes. Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
7.Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
Good Luck & cheers:-)
Jun 30, 2010 | HP LaserJet 1100 Printer
Refill toner cartridge
The toner cartridge is designed to dispose once finish... Not recommended to modified and refill...
Feb 17, 2010 | Toshiba E-Studio167 Copier
Brother Toner Refills
Yeah you can refill your cartridge. It is really easy and consists of removing the plug on the side of the cartridge, dumping out any old toner and dumping in the new toner. Its very easy. I have purchased refill kits from both of these sites in the past and its worked great:
www.tonerrefillstore.com
www.lasertekservices.com
They also have great customer service. I hope this helps!
Nov 08, 2009 | Brother DCP-7040 Laser Printer
The toner life ended and then we got a refill. Earlier on refill, It was working fine, But this time it still says , TONER life end, replace toner. We tried loading 2 different refilled toners and cleaned...
we can refil toner many times but we should reset cartage, while we refiling toner to open cartage we should sides white rings middle plastick flate white plate make adownof cartage it is first methode. when we put reffiling cartage put on printer and do on at that time we push cartage right side pointo re set. look on www.brother.com
Nov 05, 2009 | Brother MFC-7820N Printer
Refill
Hai
Well u can refill the toner,to refill the toner u should contact the nearby service station to refill.
Sep 09, 2008 | Xerox Black Toner Cartridge 25000 Page...
Refill toner in dell 1710
hi fireind
take out ur toner form your printer take the toner nearest printer ink refiller he will refill it he will chage for it $5 to 20$
Apr 08, 2008 | Dell 1710n Laser Printer
HP LaserJet 3055 All-In-One Printer Logo
46 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
