Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
The oven vent gets real hot and melts and turns the console panel brown. Is this normal
No.
Posted on Jul 17, 2009
My fagor oven cable melted. How hot should it get on the outside?
Depends on your cable insulation specification.
In the UK an electric oven requires a 32Amp supply which is normally supplied with 8mm cable. So at 110volts double the current and cable capacity.
Crimp the connection on the oven and feed from a specific fuse box.
If there is at least 2inches of clearance and the connections are tight, the cable will stay cool.
Check your local Electrical Regulations for installation specifications.
Apr 17, 2018 | Fagor Ovens
Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
Oct 16, 2017 | Bosch Ovens
Why is hot air coming out of the top of my oven
If you have a gas range they will vent the heat from the oven out the top by the rear panel. If an electric they will generally vent through one of the rear burners. I am sure that this is normal.
Nov 10, 2013 | Ovens
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
When i use the oven it stays hot after turned off. front panel, right under the touch buttons gets very hot.
This oven has an oven vent that comes out under the control panel usually to the right. Very poor design as this vents heat into the controls and can cause a control board failure, especially during a self cleaning cycle. Good Luck, Appliance Specialists
Dec 14, 2009 | Amana AEW3530DD Electric Single Oven
On a Amana EvenAir convection Plus oven the convection blower comes on during the regular bake cycle.
There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
Oct 12, 2009 | Amana AOCS3040 Electric Single Oven
Stove top hot when oven on
There is a vent tube that generally goes up to a back burner where you can use it for keeping something warm. There may be a problem with that tube falling out??? and all the heat is venting to under the stove top. Look fer it
Jun 26, 2009 | Magic Chef 9815 Electric Single Oven
Griller on simpson harmony nova oven
In my experience, it is normal to leave the the door open when grilling, otherwise it is liable to cause the bakelite handle of the grilling pan to get very hot, and possibly melt or catch fire, and make it to hot to hold the handle.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Ovens
Burn mark
Most likely the brown stain will NOT come off, if the stain comes off the paint will come with it. Replacing the control panel is the option for making it look good again. Sorry to bring bad news.
Mar 02, 2008 | Whirlpool RBS275PD Electric Single Oven
Too hot
first thing is to check if it is front vented or rear vented, if it is front vented you will find warm air blowing out above the door. if not it is rear vented and must have a flu installed behind unit.
Feb 18, 2008 | New World E70DOa Electric Double Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
91 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
