Question about HP Photosmart C4580 All-in-One InkJet Printer
Won't print after replacing cartridges
I replaced all of the cartridges in my photosmart C7180 and it is still saying I need cyan (the triangle) What should I do?
    Scholar:
  • 71 Answers
The following text copied from HP website to tackle this problem. Won't print after replacing cartridges - minimtop.gif Follow the instructions below to install the print cartridges. NOTE: If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup. s.gif Installing the print cartridges minimtop.gif
  1. Verify that the unit is on.
  2. Open the ink cartridgWon't print after replacing cartridges - c00718797.gif>Figure 1: Opening the ink cartridge door c00718797.gif
  3. Squeeze the gray tab below an ink cartWon't print after replacing cartridges - c00721793.gif release the gray latch and then lift the latch. Figure 2: Lifting the latch c00721793.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
  4. Remove the new ink cartridge from its packaging.
  5. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot. NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridWon't print after replacing cartridges - c00721795.gifr-colored contacts should be facing the printer as the ink cartridge is inserted. Figure 3: Inserting an ink cartridge c00721795.gif
  6. Press down on the gray latch until it clicks into place. Figure 4: Closing the gray latch c00721796.gif
  7. Repeat steps 3 through 6 for each ink cartridge that needs to be replaced. All six cartridges must be installed. The printer will nWon't print after replacing cartridges - s.gifrk if an ink cartridge is missing.
  8. Close the ink cartridge door. Figure 5Won't print after replacing cartridges - s.gifsing the ink cartridge door c00718798.gif
    Won't print after replacing cartridges - s.gif src="http://i.fixya.net/uploads/imaWon't print after replacing cartridges - s.gif.gif" alt="s.gif" class="h_mi" /> Won't print after replacing cartridges - s.gif s.gif Won't print after replacing cartridges - s.gifmg src="http://i.fixya.net/uploads/iWon't print after replacing cartridges - s.gif/s.gif" alt="s.gif" class="h_mi" /> Won't print after replacing cartridges - s.gif src="http://i.fixya.net/uploads/images/Won't print after replacing cartridges - s.gif" alt="s.gif" class="h_mi" /> s.gifs.gif
    s.gif s.gifHave a Good Day
Posted on Jul 17, 2009
Error: 0xc18a0106
replace the print head unit not the cartridge.
Jun 17, 2012 | HP Photosmart C7180 All-In-One InkJet...
Poor print quality hp c7180
Hi, First clean the print head and clean the nozzles. Reset your printer and select best quality printing in printer properties. Finally you have to replace the cartridges.
Sep 26, 2011 | HP Photosmart C7180 All-In-One InkJet...
The pink and magenta cartridges won't print. We have replaced them again thinking the cartridges were faulty, but still we just get yellow print. HP Photosmart C7280 All-in_One
Sounds like you need to run a printhead cleaning cycle. Dried inks can block nozzles - if they're blocked no amount of cartridge changing will make them work.
www.inksave.co.uk
Feb 11, 2011 | HP Photosmart C7180 All-In-One InkJet...
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
C7180 Print in color without all cartridges
You can usually print with an empty cartridge, even though the software will inform you that the cartridge is empty. Your print quality may be affected, however.
Dec 03, 2008 | HP Photosmart C7180 All-In-One InkJet...
Printer
If you look your print heads have a colour symbol on them and cyan is a triangle. Magnenta is a square, yellow is a circle.
Aug 28, 2008 | HP OfficeJet d145 InkJet Printer
HP Photosmart C4580 All-in-One InkJet Printer Logo
1,191 people viewed this question
Seeker5211
Seeker5211
