Question about Sony Ericsson Bluetooth handset pink SonyEricssion M600/p990i/ Z610 Cellular Phones
Restart When i switch on my phone P990i it begins reachs a certain point and then after dat it restarts and then keeps on repeating
  • 1,011 Answers
Re: Restart
did u do a factory reset or master reset with it...
if not try it by the way....
Posted on Apr 16, 2009
  • 92 Answers
Re: Restart
Please update with latest flashing software
according to me it works...............
Posted on Feb 25, 2008
0 characters
3 Points
My iPhone won't turn on
How exactly are you attempting to charge the phone? If the phone is completely dead, you should not use a USB port on a computer or a USB hub to charge it.
Instead, I recommend that you obtain the cube-shaped Apple adapter that plugs into an AC outlet if you don't already have one. It's just a little white cube that plugs into the wall, and it has a USB connector on it. Use an iPhone-to-USB cable to get the phone charging from the wall using that adapter.
Leave the phone connected this way for at least 15 minutes. When the phone gets to a certain minimum level of charge, it should display the battery image on the screen for a few seconds, to let you know it is now beginning to recharge. Note that it may take several minutes before you ever see anything on the screen. Only then will you know it's actually charging. Leave it for a while, and let it charge. If the sound is turned up on the phone, you will also hear a beep when it displays the battery image for the first time.
You can check status periodically by briefly pressing either the round button near the bottom of the phone's face, or the power button on top. It will display the battery image, which will reflect the current state of charge.
Once the phone has at least 25% or more charge on it, you should be able to power it up (while still connected to the charging source). To do so, hold down the power button on the top right edge of the phone until it turns on.
If the phone does not begin to respond after 15 minutes of connection to a known-good charging source, then it has developed a hardware problem and will need to be repaired or replaced.
I can't stress enough that you need to make sure the problem is not the manner in which you are charging it, or the adapter or cable that you are using to charge it. Try multiple cables if you have them, and obtain more than one of the AC adapters to make sure that isn't the problem. If you are using a charging dock of some sort to charge it, that could be the problem as well. You want to eliminate all other possibilities in order to determine for sure that it's the phone.
The only other weird situation that I've seen is if you have a corrupt app that is blanking the screen, making it appear as though the phone is off. To make sure this isn't the problem, press and HOLD the power button on the top right edge of the phone for at least 10 seconds or more. You should see a message that says "slide to power off". Slide the button to power off the phone. Wait until it goes completely black, then wait another 10 seconds. Then press and HOLD the power button on the top right edge of the phone again to restart it.
Jan 18, 2015 | Apple iPhone4 4G iPhone 4
My pantech p2020 is not starting
perform power flee
keep holding power button for 15-20 secs ...release and turn on
Apr 21, 2014 | Pantech Ease P2020 AT&T
Screen cell phone keeps blacking out
Restart iPhone
Sometimes all it takes is a restart for the iPhone to become responsive again. To restart your iPhone when it is unresponsive, press and hold the sleep/wake and home buttons until the Apple logo appears (~10 seconds).
Very low battery
It is possible for an iPhone to become unresponsive if the battery drops to an extremely low level. Plug the iPhone into your computer or wall charger and allow it to charge for at least 20 minutes before using it again.
May 23, 2013 | Pantech Ease P2020 AT&T
What does repeat mean on my mp3 player?
It means that your selected song/item is on repeat. It will keep playing again and again.
May 25, 2011 | Gomadic Classic Straight USB Cable for the...
I ve changed I phone 3GS to 4 , I ve back up already , all the games transfer to new phone. Other games record also can move to new phone,but How come Fashion story,Restaurant Story, Bakery story s record...
Unfortunately, there is no solution for your problem. Certain games keep their information stored in a partition on your phone which is not copied when you transfer data to a new phone. This information could be accessed if both of your phones were jailbroken, but as it is, you may need to restart those couple of games.
May 02, 2011 | Apple iPhone4 4G iPhone 4
Can not ring out or recieve calls keeps showing error conection
The number one reason for this problem is that the phone itself was trying to connect to a tower when you switched to another. This happens a lot and normally it self rectifies but sometimes it is not able to handle the change.
The fix is quite simple:
1. power down the phone and restart. This should fix the phones problems almost instantly.
If that fails, remove the battery and hold the power button for 10 seconds. Reinsert the battery and start the phone again. This is a variant of the above which "resets" the phone.
Finally if neither solution work your best bet is to use another phone to contact the manufacturer. Inform them that the phone is no longer getting a signal. If you make sure to stress it is a manufacturing defect of the chip they will almost certainly replace it for free.
Feb 28, 2011 | Orange PCMICROSTORE Brand Nokia 5300...
My G1 keeps restarting by its self it turns on then after a while it will restart over and over again.. what is the problem with the phone?
uhh , maybe , your battery is dieing ? i mean like you need a new battery . Call your companyy would be tha best thing to do
Apr 12, 2010 | HTC Google G1/Dream Cell Phone Black...
My phone model no. w350. asking puk no. what to do?
Inorder tosolve your PUK problem, *kindly contact your service provider (customer care) *Tell your phone number and they will give your PUK code *Enter that code on your cell phone(that ask puk code) *Then your phone ask another pin code&to verify,there you can type your desired code(say 0000,00000,1234,12345). * Then your phone will restart normally.... "IF YOU THING MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
Sep 16, 2009 | Sony Ericsson Bluetooth handset pink...
How to connect a sonyerricson bluetooth device with my k800i
From the Menu screen, select Settings. Scroll across to the Connectivity tab and select Bluetooth. Select Turn On. To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree. Your phone will then look for a handsfree device to connect to. Press and hold the 'call' (big) button on your bluetooth device. First it will blinks once, keep holding, then it will turn to steady blue. This is the 'pairing' status. When the phone found your device, select the device and enter the passcode (usualy 0000 (4 times zero))if required. The steady blue light on the device should go off and blinks every couple of seconds. Next time you switch on the bluetooth device it will be automaticaly recognized by the phone.
Jun 14, 2009 | Sony Ericsson Bluetooth handset pink...
Reg Touchscreen
first of all calibrate ur touch
then if not works
please change ur touch pad
Sep 20, 2007 | Sony Ericsson Bluetooth handset pink...
Sony Ericsson Bluetooth handset pink SonyEricssion M600/p990i/ Z610 Cellular Phones Logo
115 people viewed this question
Top Sony Ericsson Cell Phone Accessories Experts
Prashant  Sharma
Prashant Sharma
Are you a Sony Ericsson Cell Phone Accessory Expert? Answer questions, earn points and help others
