Question about Dell Dimension 9150 (DIM915MIN) PC Desktop
Bios problem, need to reinstall windows xp pro x64
Dear Sir/Madam, I have tried to reinstall windows using a retail version as I have lost the recovery cd.
Anyway,the reinstall freezes at "acpitabl.dat"
I researched it and found that I need to enable ACPI in the bios. However when I press F2 to enter bios, the bios outlay is like nothing I have encountered before.
There is no option under power management to enable BIOS.
Please help me as I urgently need to use this system to run my business.
Thank you in advance
  • 44 Answers
Try again installing the windows...
Posted on Jul 17, 2009
Windows 7 driver needed
If you have Windows 7 32-bit, the XP driver will probably work. http://www.driverguide.com/driver/detail.php?driverid=754345 has a copy. However most copies of Windows 7 are the x64 version. To check your OS version, click on Start and choose the Control Panel from the right hand column. Click on the System and Security link and then the System link. Read the version information. If it ends with x64, you aren't going to find a driver. You can try the compatibility mode with this driver but it often doesn't work for drivers. (Right click on the exe after downloading and choose properties. Go to the Compatibility tab and try setting it to Always Run in the compatibility mode with XP. Then right click again and choose Run As Administrator.) You may need to repeat this for the installed software as well; note the folder destination for the files.
If you have Win7 x64 and the compatibility mode fails, you would be better off upgrading to Windows 7 Pro and installing Virtual PC and XP mode. Then use the above driver in the XP virtual computer that is created. Alternatively, look into getting a new racing wheel controller that has a Windows 7 x64 driver.
This product was produced for systems with 16-bit and 32-bit versions of Windows. Since Microsoft requires digital signatures on x64 drivers, there would be significant costs to writing new drivers and getting them approved and signed. I'm not sure Game Elements is still in business.
I wish that I had better news for you.
Jan 16, 2014 | Game Elements HV-5 (GGE904) Wheel And...
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
I used twinkle cam successfully in windows xp. I have upgraded to windows 7. How do I get the driver or will anything work?
According to http://www.chicony.com.tw/download/di/driver.asp , the available drivers were written in 2004. Chicony has stopped supporting their cameras for newer Windows OS versions. I suspect they never made a 64-bit version of the driver for XP 64-bit.
If you had the 32-bit version of Windows 7, you might be able to use the compatibility mode to install the driver. To check your version, click on Start > Control Panel > System and Security > System. Look for your Windows version and check if it says x64. If you see that in the description, you have the x64 bit version. Otherwise, right-click on the driver file from the above site (after extracting the files from the zip file). Choose Properties and the Compatibility tab. Check the box for always Run this program in the compatibility mode and set it to Windows XP in the drop-down menu. You may need to repeat this on the camera software as well.
If you have a 64-bit version Windows Home Premium, you may be better off upgrading to Windows 7 Pro or Ultimate. Then you can download and install Virtual PC and the XP mode, if your hardware can handle that software. This gives a virtual version of the 32-bit version XP that will run your camera. (The CPU needs to have virtualization support and it has to be enabled in the BIOS. Then you need enough memory to give the virtual XP at least 512MB -1GB of memory.) If you already have Windows 7 Pro or Ultimate, just use XP mode. Other virtual PC software exists but they require a licensed version of XP. (If you can find a valid license.) The only issue I've found is that files saved to the C: drive in one OS can't be accessed by the other OS. You have to transfer the files with an external drive, flash drive or burn the file to optical disc.
Dual boot systems with XP and Windows 7 can be set up if you have the XP license. Then pick the OS you need when you boot up the computer. This requires you to repartition the hard drive or have two bootable hard drives. Make sure to back up before partitioning the drive.
Aug 22, 2013 | Chicony TwinkleCam DC2110 Webcam
Dear sir, I have a sound device problem. System
no problem with the configuration i guess.. try to reinstall the sound drivers or uninstall the current drivers and install generic drivers by manufacturer i.e Lenovo
Jul 31, 2013 | Lenovo ThinkPad Computers & Internet
I downloaded the driver but it wont find it and i have windows xp pro x64 does it not work on this ver
try reinstalling it with this one, its neer the bottem of the screen.
http://www.jascoproducts.com/support/software-downloads.asp#pccams
Sep 21, 2008 | GE EasyCam Pro Webcam
Installed win xp pro x64 onto nascar notebook and all drivers were lost.
You will have to go through each drivers website and get the Windows XP 64 bit drivers.
Here is Neros website:
http://www.nero.com/enu/index.html
If the CD that came with your computer isn't working you will probably have to purchase a new one.
Jul 05, 2008 | ZT Group NASCAR M2002 Notebook
Problem in installing windows XP
Maybe a bios update is needed.
Mar 27, 2008 | MSI 945GCM5 Motherboard
Enter BIOS on boot
According to the intel manual the key is F2
"The BIOS Setup program can be used to view and change the BIOS settings for the computer. The
BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST)
memory test begins and before the operating system boot begins."
That is from the manual for the board, instead of reinstalling Windows you may as well just change the product key on one of the installations to your other copy.
Mar 07, 2008 | Intel D850MV Motherboard
Can not install win xp on MS9158E MATSONIC motherboard
Dear Sir/Madam,
I install the winxp in MS9158E matsonic motherboard and after installation sound card not working. Mean sound not coming and i search the drivers from website but i didn't found the sound driver from web. So, I request you to please help me for download the driver for specific motherboard.
Jan 17, 2008 | Matsonic MS9158E+ Motherboard
Dell Dimension 9150 (DIM915MIN) PC Desktop Logo
208 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
