Question about Heavy Machinery
A/C compressor isn't kicking on. No voltage to pressure switch on dryer. Control panel seems to be working fine. Need wiring schematic
  • 749 Answers
If the Freon is low the pressure drops and the switch will not see ground. Add Freon as needed.
Posted on Nov 20, 2017
SOURCE: Ac compressor won't kick on
Just had the same issue and posted. Just found the solution is the control module in the dash. Went to the junk yard since new is expensive on these units. Plugged new unit in, was able to charge a/c now blows cold as ice.
Posted on Jun 11, 2009
co7196
  • 3433 Answers
SOURCE: I need a wiring diagram for the ac to find the high and low pressure valve and the compressor switch .
No you don't. The hi/lo awitch is on the tubing at the drier.
Posted on Jun 27, 2009
  • 5 Answers
SOURCE: I cannot locate my low pressure switch on 1995 Corsica.
First of all, from the discharge port of compressor to the condenser(the device in front of the radiator) from the condenser to the metering device is all the high side or high pressure. From the metering device through the evaporator including accessories back to intake of compressor is the low side or low pressure.It is important to know that entrained in the refrigerant is oil for lubrication. The combination of pressure and oil could be a safety and environmental hazzard. I know on older GM models one could short out low pressure switch by jumping the low pressure switch with appropriate gage wire. This would temporarily permit one to add aditional refrigerant to system.The job of the low pressure switch is to protect the compressor from burning up due to lack of refrigerant by shutting the system down.. Now, if the refrigerant is low it had to escape, meaning a leak.(refirerants don't just wear out)Refrigerants are notorious to being determental to the environment. Older refrigerants contained hydrocarbons that destroyed or reduced the ozone levels to reduce this from happening strict laws of handling and recovering a/c refrigerants were enacted & exhorbitant costs were placed on the offending refrigerants.In order to save some some money some untrained or knowledgeable people are continuing attempting to repair their systems risking injury like permanent eye injury.Is it worth it? No one (I believe ) intentionally desires to be hurt.However, by attempting to do something that you haven't been trained on can make you more susceptable to injury or accident. An in a instan one could trade off perfect vision to partial or even total blindness.This is not to just to scare you but gives you an opportunity to weigh all the decisions prior to attempting something one might be unfamiliar with.Most of the accidents I've witnessed at home and work were individuals taking short cuts,hurrying or attempting something unfamiliar with.Not all accidents fall into this category but be aware rehab is no fun and often not totally complete. Lets not compromise your safety and the well being of our environment.
Posted on Jul 05, 2009
thumper221
SOURCE: 1998 Ford Explorer a/c not working properly
Had the same problem on 98 Eddy Bauer we have. Have you noticed that it has a tendency to belch out hot air and the blower speed slows down mostly when you accelerate or give it a little more gas to climb a hill or an overpass or even pass somebody? If this is the case there is a pressure switch that's hooked into the intake manifold were it can sense a drop in pressure and when it does it drops the ac clutch out and slows the dash blower down till the pressure comes back up. JUMP IT OUT. All your problems will go away. Thats in there to unload the engine during acceleration and heavy loads and after the switch ages it gets trigger happy and lazy about closing to bring the ac back on.
Pat - Houston
Posted on Sep 09, 2009
pleddy
  • 43 Answers
SOURCE: air conditioner relay location 2004 passat
hi,
the a/c pressure switch is located to the left side of the condenser radiator, as you stand in front of the vehicle. you may have to remove the bumper in order to get access to this switch.
there are 2 relays dealing with the a/c , numbers 16 and 17, on the relay plate at the drivers knees, the plastic panel will have to come down. 16 is the clutch relay and 17 is a/c control module.
hope this is of some help
Posted on Jul 29, 2010
I have a Arctic King through wall AC model MWW-12ERN1-MI0 and the compressor will not engage to cool the air. Can anyone help me diagnose and fix this problem?
On the ac unit electric section, check for power at Y1, should have power, possibly to x or c ( common terminal).
Check for power across the compressor contactor, should have power or something is open such as a pressure switch or compressor protection. If there is control power at compressor contactor solenoid ( 24 volts control), then check for supply power on line side of contactor, then on load side of contactor (supply voltage e. g. 230 volts. If all voltages are present, then check the compressor for opens and electric continuity.
CAUTION: electricity is dangerous, can kill and/ or cause fires. Do not attempt if not aware of safety procedures.
Aug 08, 2017 | Heating & Cooling
Free wiring schematics
You didn't say what type compressor you have and didn't say what voltage.
A 220 volt compressor should use a double pole switch .
A 120 volt compressor only needs a single pole switch'
how to wire pressure switch for compressor YouTube
Aug 24, 2014 | Air Tools & Compressors
A/C Compressor won't turn on Can jump compressor from battery and compressor comes on & cools. Hi pressure switch checks out ok and 12 volts going to hi pressure switch no voltage to compressor
the high pressure switch kicks the compressor off when the pressure rises, the low pressure switch kicks it on, check that switch, unplug the wire and use a continuity meter to see if the switch functions, also check for power getting to the plug itself
Sep 25, 2011 | 2002 Chevrolet Blazer
Bought this LG unit (LWHD7000HR) summer of 2010 and it worked fine - used very rarely. Did not use heat in winter either. Went to turn it on this summer and it does not cool. Fan operates but compressor...
Unplug the a/c and check the control panel of your a/c. Unscrew the control panel to expose the wires and terminal lugs.Check for lose wires or terminal lugs or defects from the compressor capacitor. If all are OK try adjusting the thermostat switch to make the contacts work. If the capacitor is damage replace it and replace any damage terminal lug. If the compressor still does not work, check the overload and the compressor resistance. If overload is open, replace it and check compressor amperage. If the compressor amperage is high, you have to replace the compressor, vacuum, and recharge freon.
Sep 02, 2011 | LG Heat cool Window Air Conditioner
I have a 02 lincoln ls . the air conditiong is not working . i took it to a local shop they check the compressor, fuses, relays, pressure swithches, all is checcking out good. They jump the compressor...
YOU COULD HAVE OPEN OR SHORT IN THE BLACK YELLOW WIRE GOING TO AC COMPRESSOR CYCLING PRESSURE SWITCH. CHECK FOR A SHORT OR OPEN IN RED YELLOW WIRES AT THE AC PRESSURE CUTOFF SWITCH. USE VOLT METER AND CHECK FOR VOLTAGE AT BOTH SWITCHES. PROBLEM COULD BE IN THE EATC MODULE THAT SEND POWER TO PURPLE WIRE THAT FEEDS THE AC PRESSURE CUTOFF SWITCH AND AC CLUTCH CYCLING PRESSURE SWITCH THEN FEEDS THE AC COMPRESSOR CLUTCH SOLENOID.
Jun 24, 2011 | 2002 Lincoln LS
Whirlpool dyer will not work, have replaced the board but
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker. I have checked every part in the entire unit. That was over 2 years ago. I still need to get a control panel and see if it fixes mine but after dropping $130 on the control board, i feel i could buy another dryer with the $200 they want for the control panel. Also this dryer seems to streak my clothes with brown or rust colored spots. The dryer is spotless inside. I even took off the rubber seal because i thought the glue is what was possibly doing it when it heated up but that didn't help either....This dryer sucks.
Dec 21, 2009 | Whirlpool GEW9250 Electric Dryer
No power to selector panel
Dec 18, 2009 | Whirlpool GEW9868K Electric Dryer
99 Suburban A/C Not working
The A/C pressue switch may be bad as well. Also the mode switch on the control head inside the vehicle. There are many other exsisting problems pertaining to a/c. I suggest a manual from Auto Zone for many faults can be noted especially wiring can be at fault
May 23, 2009 | 1999 GMC Suburban
Whirlpool dryer MOD: GEW9868KQ2 - touchpad not working
Aug 16, 2008 | Whirlpool Dryers
Heavy Machinery Logo
243 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
