Question about GE Profile JTP18 Electric Single Oven
GE JTP20BF1BB Oven sensor connection melted together. How do I connect a new sensor to the oven wire? Can I splice the wires and forget the attached plastic connector?
  • 3,600 Answers
You can buy the new sensor here http://www.appliancepartspros.com/partsearch/ and they give you thermal **** connectors to handle the heat.
Posted on Jul 17, 2009
  • GE Master
  • 3,361 Answers
Yes, you can splice the wires. Use ceramic wire nuts.
OVEN TRIPS OUT
Posted this several years ago. It's possible the oven sensor has gone bad or lost connection. Try cutting out the little plastic electric plug that connects the sensor to the oven wiring. Then hard wire it together with two small wire nuts.
If that doesn't work, you will need a new sensor, as we did. But when we installed it, we used the little plastic electric plug to connect it. Two days later it started acting up again.
The instructions said to hard wire it with two small wire nuts, but since it came with a plug it made sense to use it. Finally, even though it didn't make sense, I cut out the plastic plug and hard wired it. It's been about 3 years now and we've had no further problems.
THERE IS SOMETHING WRONG WITH THAT LITTLE PLASTIC ELECTRIC PLUG. YOU MUST NOT USE IT. HARD WIRE IT.
Mar 04, 2014 | Hotpoint SY36 Style Line Stainless Steel...
Thermostat on hot point stove
Posted this several years ago. Don't know if it's the same oven. It's possible the oven sensor has gone bad or lost connection. Try cutting out the little plastic electric plug that connects the sensor to the oven wiring. Then hard wire it together with two small wire nuts.
Jan 18, 2014 | Hotpoint SY36 Style Line Stainless Steel...
GE JTP20 oven. Do I need to replace light fixture after spark from a short?
First, no First, no First unplug the range after you gently scoot away from wall. Then check youy main circut breaker for house to see if you tripped fuse. Then with stove still unplugged remove back access panel, look to area where light goes into oven. Check again and make sure oven is unplugged, then repair the wire by splicing wire with new wire line splice purchased at your nearest local auto parts store, sales person can show how to install. THEN plug in to see if you can see the light!
Joe Don
May 25, 2012 | GE JTP20 Electric Single Oven
How do you replace and oven sensor in a JTP15 wall oven?Getting F3 error code and ordered the part today but it doesnt come with instructions.
You will need to shut off the power and remove it from the wall. Remove screw holding sensor from inside oven. Then pull rear panels off to access rear of machine, be sure to tie a string to the old sensor wires so that when you pull them through you can tie the new wires to that string to make it easier to pull them back through. Plug new sensor wires in, put oven back together and re-install.
Please rate my solution if it was helpful.
Thanks, Repairman45.
Dec 02, 2010 | GE JTP15 Electric Single Oven
How to change the bake element in a GE stove
Unplug or turn off all power to the oven. With most ovens you can then unscrew the element from inside the cabinet with either a screwdriver or a 1/4 nut driver. carefully pull the element out with the wires attached and dont let the wires go back through the holes. Unplug or unscrew the wires from the old element and plug into or screw onto the new depending on the type of terminal. If it is a push on type terminal make sure the connection is tight, if they are not tight pull the terminal back off and tighten the gap with pliers and recconect. put it back together and you are done. If by chance the wires are not long enough you will need to pull the stove out, remove the back panel and make the connections from the back. Good luck, it is not hard.
Dec 13, 2009 | GE Ovens
After the oven is on for about 30 minutes F2 comes up and it continues to beep
F 2 : Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Sep 14, 2009 | GE Ovens
F3 message comes on after a minute or 2 on ge oven
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Apr 12, 2009 | GE JTP20 Electric Single Oven
Oven wont heat (igniter help needed)
Once again...I apologize for not getting back to you sooner. My email notification doesn't seem to working.
The part number for the bake igniter is WB2X9154. You can order a replacement part online at any of the following websites: searspartsdirect.com, repairclinic.com, pcappliancerepair.com or appliancepartspros.com. I recommend these sites, because they seem to offer the best service and offer competitive pricing. I would recommend checking all of them for the best price.
You do not need to remove the oven floor to access the connector wires for the igniter. Remove the lower drawer for access. Make sure you unplug the stove and turn off the gas before servicing. As stated before, the new ignitor may or may not have a matching plug to fit your range. If the connector does not match, there will be guidance provided with the new ignitor that instructs you to cut the wires and splice using heat resistance ceramic wire lugs. They should be included with replacement kit. DO NOT use standard wire lugs. They will melt. Let me know if you require further assistance. I hope this helps you.
Dec 14, 2008 | GE JGRP17 Gas Single Oven
F3 Fault
Either your new temp probe failed or there is a wiring problem between the probe and the electronic relay control.
Jul 29, 2007 | GE JKP28 Electric Double Oven
GE Profile JTP18 Electric Single Oven Logo
127 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
