Question about Boating
1990 650sx, ran good one day then would not do nothing next morning. battery is good but no juice is getting to starter. is there a bad celinoid,coil, condenser? it is not turning over.
    Champion:
  • 207 Answers
More than likley the solenoid is bad need to know what kind of ski it is to tell where it is located
Posted on Jul 18, 2009
2000 blazer will not start did a manifold gasket job, replaced plugs, wires, distributor cap,new fuel filter. Cranked and ran really good for 2 days then will not crank
Check you starter, maybe you have a loose connection. Try to give direct power to the starter and see what's happening. I nothing happens, you have a bad starter.
Mar 16, 2013 | 2000 Chevrolet Blazer
Brand new will not start
like no juice? if no juice bad batt.. i just baught a new supermoto rode it 0ne day.. came out next morning no power.. nothing... tried to jump to take to dealer no power.... took batt. to dealer picked up new batt. under warrenty... went home power....
Apr 09, 2011 | Triumph Bonneville T100 Motorcycles
My 2004 pontiac grand prix gt wont start when i went to turn it on this morning to go to work nothing happened it just made a clicking noice. The guy at pep boys said that the battery was good. when i try...
if you turn headlights on and turn key to start do you hear clicking? if so starter is possibly bad,lets trouble shoot your problem.suggest you check the fuses under hood in black box,make sure those are good. when you turn the key, you should hear at least a click or else the starter is not drawing current.try turning the headlights on and at same time turn the key and try to start, if lights go dim the starter is drawing current, does it click? if so then bad starter. if no noise at all,,still could be a bad starter.suggest that you remove the starter and have it checked out.also make sure the car is in park for sure before you do any of this. hope this helps!!
Sep 13, 2010 | 2004 Pontiac Grand Prix
Cranks but won't start like it has no gas
did you reset the alarm/immobiliser system every time the power was disconnected???
May 21, 2010 | 1997 Volkswagen Jetta
Car was running the day before. Next morning, got
Try having one person turn the key to the start position and hold it there, while someone else taps on the starter with a hammer. If tapping on it makes it work, you need a starter. Good luck. Hope this helps.
Jun 07, 2009 | 2002 Ford Taurus
Motor cycle will not start after sitting a day or two
You have an open circut some where. If you have an alarm system start with that.
May 02, 2009 | 2001 Harley Davidson FLSTC - FLSTCI...
Car wont start, no clicks no sound
make sure you have power getting to your starter when you crank. check the small nut on the starter. should have 12 v or very close to it. this will tell you if your getting power to the starter or if somethign before the starter and something maybe with your anti theft system or not. its hard to say online cause of that anti theft. doest the light flash at all? the anti theft light?
if your getting power to the starter when you crank make sure your getting good power to the starter by turning on the head lights and see if they dim. a good starter will cause the headlites to dim when attempting to start. if nothing dims check connections. or assume bad starter motor. make sure your also getting power to the main starter stud as well.
good luck
michael
Apr 29, 2009 | 2000 Buick LeSabre
2004 A 8L won"t start
starter wont click because there's not enough "juice" to turn it over. this isnt because of the battery as you have just replaced it. it is due to a bad alternator recharging the battery as you drive. if it were only a fuse it would be the solenoid in the starter. but if it had started after you installed the battery then its not the solenoid. solution: buy a refurbished alternator and
Apr 24, 2009 | 2004 Audi A8
Car will not turn over
The most common problem would be a bad starter. The clicking sound is not always heard in a bad starter. The mentioning of no attempt to turn over shows that the process stopped at start (bad starter) Check the positive cable on the starter for corrosion. Otherwise, you will have to replace the starter. The problem is intermittent,stay aware It might start 2 or 3 times then out of nowhere. it will start give you problems. Avoid the headache, replace the starter.
Nov 17, 2008 | 1998 Oldsmobile Intrigue
Boating Logo
77 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
