My Kenmore Elite (Top Load) Bleach Dispenser is filling during every no (no bleach is added) and water does not seem to be draining out of it, and it sprays the inner wall of the meatl shell, ending up puddling on the floor. Does the hose that extends from the bleach basin down to the actual tub wall come off? Could it be plugged and just needs to be cleaned out? I have detached the hoes that jets water into the bleach dispenser so that it just dumps into the wach tub during the cycle.
I have this same problem today and did not need to take off the top panel or remove the front panel/housing. The bleach and frabric softener dispenser snaps right out and you can check the tubing and clamp from there. You will need to remove the top panel if you need to replace the tubing. In my case, there is a crack in the dispenser itself which has ruined several loads of laundry over the past year...now I realize it wasn't the clamp and hose, but the dispenser itself. Check them all while you are at it.
Thats about all you can do unless you are going to replace the whole bleach container and hoses.
I removed bleach dispenser to clean but it still does not work properly
