Question about AOpen VKM266PM Via Socket A MicroATX Motherboard / Audio / AGP 4x / 10/100 Ethernet LAN / USB 2.0 /
Main board manual - AOpen VKM266PM Via Socket A MicroATX Motherboard / Audio / AGP 4x / 10/100 Ethernet LAN / USB 2.0 /
  • 137 Answers
There should be all the infos you need:
http://www.opendrivers.com/searchopendrivers/PM-page5.html
Posted on Jul 17, 2009
Sony bravia flat tv model KDL46S2010 only power light comes on nothing else.
You have either a bad main or power board, start by checking your PSON voltage if you have a multi meter and comfortable doing it, if its normal then replace the power board if its missing but the standby voltage is correct its the main board. Below is a link to the service manual for your TV
Sony KDL 23S2010 Service Manual
Feb 04, 2018 | Sony Televison & Video
I have a Panasonic Th-58PX60U Plasma TV with a sound issue. I was able to get sound out of internal spkrs briefly and the lost and none out of external jacks.
I didn't take the time to look in the manual on your set but believe the raw DC comes from the PS board to the main and its reduced on the main so I would go with the main board. Here is the service manual for it
Panasonic th 58px60u Service Manual
Feb 04, 2018 | Panasonic Televison & Video
SAMSUNG 42" TV screen/picture fades to dark. Only comes back if I press volume control!? First noticed image darkens shortly after turning on the tv, now its constant.
like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Repair/service assistance to electronic equipment
The author of the site http://electronicshelponline.blogspot.com/ is now to provide online repair/service assistance to electronic equipments. With more than 50,000 of service manuals and user manuals to different type of electronic equipments; Students and service professionals in electronics can now make the benefit of it. Contact: gopalan.gopakumar327@gmail.com
Aug 27, 2016 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Is the audio amp on the main board of a sharp lcd tv
A manual for a measure of the voltage line thats goes to the audioboard and there can be used a fuseresistor a resistor to protect the audioboard if .......
SHARP LC 32M44L LC 32SBB21U LC 32SB23U LC 32SB220U SUPP Service Manual...
Suc6
Oct 25, 2015 | Sharp LC-32SB23U 32 in. LCD TV
Kyocera km-1500,showing error code A-0210,solution
A communication problem between main board & engine board.
Chk the connector YC3 on main board & connector YC3 on engine board. chk terminal continuity, if not replace the terminal. Very rarely main board or engine board may go bad.
If you are facing any difficulty, download the manual go through it..
Sep 04, 2015 | Kyocera Office Equipment & Supplies
Is there a repair manual for insignia NS-LT-DVD-26?
Service manuals are hard to find now a days, even service parts. Check the link provided to find the main board for your LCD.
Finding the tuner alone might be hard or if you do, it might cost you the same as replacing the entire main board.
Let me know if you need further assistance. Insignia E23546 Main Board For Insignia E15318G NS LTDVD26 09 V260B1 LN1
May 06, 2014 | Insignia Televison & Video
Ge dpgt750
test the main control board. God bless you
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Jul 09, 2013 | Dryers
How do I test the y-sustain main board from a philips plasma tv...tv model is 42PF7220A/37 the Y-Main sustain number is LJ92-01200A....both buffers tested bad but now I dont know how to test the y-main...i...
Hi.
As such boards are cheap and fail quite easily (both the two sustain and the buffers) Philips service manuals are more oriented at board swapping then at proper testing. In this particular case the buffer boards fail very easily because of a bad soldering to IC. The short will regularly blow the main sustain board.
To start when a main sustain (e.g. Ysus) is fried the TV will go in protect mode with the led flashing in standby. One test is done disconnecting the Sus board (with power off) and restarting the TV. If TV does not go in protect, then the sustain board was good.
If there is no protection:
The first thing to check on a main sustain board is the fuse. If the fuse has blown the IC is probably fried.I believe fuse is F5004. Check for swollen capacitors that may have blown. Test the FET. That is the core of the board as it is the power amplifier.
Here the service manual:PHILIPS_SM_15540.pdf - Right Click "Save Target As"
Here a more useful service manual. Check and follow troubleshooting diagrams in manual.
Here some troubleshooting from users.
Note:if buffer board was shorted, then the main sustain board is usually faulty.
Regards.
Ginko
Sep 13, 2011 | Philips Televison & Video
I have no power to usb ports
you may check whether those ports are connected to the main board. There are some jumper style outlet on the main board for USB ports but may not be connected. Check the print on the main board or the manual you will see them.
Feb 13, 2011 | Gateway GT4010 (RBGT4010) PC Desktop
AEG OKO LAVAMAT 86820 Update .Its dead.How can i fix it, but first, open the door without being pluged ?
Hi.
First you need to do an emergency emptying by accessing the filter.
Follow page 34 and 32 in this manual.
If you repute the solution helpful, then please do not forget to accept the solution.
Thanks.
Ginko.
Sep 13, 2010 | AEG Washing Machines
Computers & Internet Logo
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
