Question about Candy CDC266 Dryer
Not heating up
Heating element not heating up during std. drying cycle.
  • 547 Answers
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Posted on Jul 19, 2009
My kenmore dishwasher doesnt heat during drying
The heating element is burned out or the heating circuit is fubar.
Sep 08, 2016 | Kenmore Dishwashers
My washing machine model no ewf 1421,is writing e60,why
Insufficient heating measured by the main board during washing cycle and also during drying cycle at washer-dryer.
Could be faulty: heting element, pressure switch, NTC sensor, printed circuit board (PCB),
wiring between PCB - heating element,
wiring between PCB - NTC sensor,
wiring of pressure switch.
Dado
Nov 20, 2014 | Electrolux Washing Machines
How do you turn up the heat on the dish washer drying cycle?
There is no way to turn up the heat of the dishwasher during the drying cycle. As part of the current ecological, energy-saving, environmentalist-wacko movement, dishwasher makers have cut back on the heating used to dry dishes. But you can do these things to help with drying:
1. It is imperative that you use rinse-aid (Jet-Dry). This allows more water to flow off the dishes and what flows off does not need to evaporate.
2. If the dishwasher has the options, turn on high-temperature wash and sani-rinse. This gets the dishes hotter for better evaporation during the dry cycle.
It is possible that the heater may not be working at all, and that will cause poor washing performance and no drying. That problem can be caused by a bad heating element, or by a bad controller.
Sep 21, 2014 | Whirlpool Dishwashers
AEG F60873 temperature problems.
The problem when the dishwasher does not heat is failure which requires to remove the qualified personnel and therefore error code is not shown on the display but it is visible in the service mode.
Possible error causes:
faulty heating element
wiring between heating element and PCB
PCB (printed circuit board)
Dado
Aug 24, 2014 | AEG Dishwashers
Dishwasher does not dry dishes. dishes are not hot at end of cycle. seems like heating element is not heating
Connect a volt meter one lead at each terminal of the heater. Read the voltage when it is in the drying cycle. If you get about line voltage the heating element is bad. If you get no or very little voltage it is the timing unit. If you are uncomfortable measuring voltage remove one of the wires from the heating element, after unplugging it, then connect a ohm meter across the heater. If it reads above about 50 ohms it is bad, if not probably the timer. Of course you could always connect a light bulb across the two heater terminals and if it lights during the drying cycle the heater is bad.
Good Luck,
Gil
Mar 01, 2010 | Dishwashers
Not drying dishes
Without knowing the make and model of your dishwasher, the most probable causes of no drying is:
1.) RinseAid being empty or not dispensing (as in you never seem to have to refill the dispenser.)
2.) The Heating element has failed. But if it has failed, you would also have foggy, film on your glassware.
3.) The timer is failing to turn on the heating element during the (at least) the heating element during drying cycle.
Good Luck!
Apr 06, 2009 | Dishwashers
Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Mar 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
No heat
If there is no heat during drying cycle, it is usually either the heating element, or a thermal fuse.
See the following suggestions from repairclinic:
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 19, 2008 | Splendide 2000S Vented Washer/Dryer
Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Jul 19, 2008 | Dishwashers
Candy CDC266 Dryer Logo
379 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Candy Dryer Expert? Answer questions, earn points and help others
