Question about Husqvarna Huskylock Computerized 910
Huskylock 901 I have a standard huskylock 901. The handwheel keeps getting stuck. I tried oiling but it only helps for awhile (1 hour maybe). I can hardly turn the wheel by hand. Any suggestions on what I can try before I have it sent in for repairs?
  • Anonymous Mar 19, 2014
    need to know that # for the standard presser foot for the Huskylock 901. Thank you!
  • Anonymous Mar 27, 2014
    My huskylok 901 was stopped running even switch turn on and light on. Press the pedal nothing is going on happen.
  • 110 Answers
Your problem may be twofold. One, the motorbelt may be too tight. Remove the sidecover and loosen the two screws on the motor. Adjust the belt tension in such a way that if you oress with your thump halfway between the motor pulley and the handwheel, the belt should give way app. 15mm.
Check if this help. If not, you need to wash your machine with white spirits to get rid of old oil and grease. Best done by a technician.
Posted on Nov 28, 2007
Husqvarna Huskylock 936. Handwheel won't turn, machine hasn't been used in a long while.
A thorough clean and oil would probably do wonders for the machine. These old mechanical machines are dependable but they do need some regular TLC because the old oil dries out and glues things together. I recommend not trying to run the machine until the problem gets addressed because it could damage the motor trying to run parts that are stuck together.
Below is what I've done for old sewing machines that have been neglected. Also, about once a year I perform a thorough clean/oil on my mechanical serger (as well as all my sewing machines). On my serger, I can remove the bottom (because that's how mine opens) and get to the moving joints inside.
Wheel on right side that controls the needle up and down is very tight...
Nov 15, 2017 | Husqvarna Sewing Machines
How can I fix a stuck needle bar on my Bernina 730?
If this is a Bernina 730 Record, it needs to be cleaned and oiled. Do not attempt to run the motor if the mechanics are stuck as it could damage the motor.
Consult your owner's manual in the Maintenance section, use only good quality sewing machine oil (NOT old stale oil, 3-in-1, WD-40, or cooking oil) and apply 1-2 drops every place that metal rubs on metal (while you hand-rotate the wheel). Pay particular attention to your problem areas--the needlebar area and the handwheel area (Do NOT oil the cams, the belts, or the plastic gears!!) To speed it up, you can direct hot air from a handheld hairdryer into the internal mechanics. (You may have to repeat several times over several days depending how "stuck" things are.)
If you are impatient, try to find a bottle of liquid Tri-Flow Synthetic Lube at the hardware store or bike shop and use it in place of the sewing machine oil. Once the machine is running smoothly again, you can use sewing machine oil or continue to use Tri-Flow in its place.
In the future, following the instructions in your manual, clean and apply 1-2 drops oil to the shuttle/race every time you change a bobbin (about every 8 hours of constant sewing), do a thorough but light oil as explained above every 40 hours of sewing, or if in storage or not in regular use, every 6 months. If it hasn't been used in a while, always give it some TLC before asking it to work for you.
Sep 17, 2015 | Sewing Machines
Why is hand wheel stuck?
If it is a mechanical sewing machine (pre-1990), it most likely needs cleaning and oiling. (Old oil has turned to goo and is sticking things.) Consult your manual. Use good quality sewing machine oil (NOT 3-in-1, WD-40, cooking oil, or your grandmother's sewing machine oil). Apply only 1-2 drops each spot as instructed. Concentrate on the area around the handwheel since that's where your problem is, but the entire machine should be oiled. You can direct hot air from a handheld hairdryer into the interior mechanics to help loosen things. Let cool and test. Wiggle the handwheel and see if things have changed. Repeat oil/heat until your machine is working again. In the future, be sure to clean and oil every 8-10 hours of constant sewing or at least every six months if not in use.
Or take it for service to a good sewing machine repair service.
Aug 10, 2015 | Sewing Machines
How can I fix a jammed, squeaky hand wheel?
This sounds like a bushing in your serger or the upper looper shaft heats up with use. This the swells the metal and seizes the machine. This is always hard to fix right because there are many points on the serger that need regular lube and can heat up. it is an eliminate 1 joint at a time and try agein
May 28, 2014 | Husqvarna Huskylock Computerized 910
Why is my handwheel hard to turn and making a squeaky noise?
Sounds like possible thread in the gears, or the wrong oil might have been used to oil the machine. Sewing machine oil (clear oil) should be used for oiling the machine. I use an oil called Tri-Flow Lubricant which is available at your local bicycle repair shop.
Bernina Record 730 hand wheel stuck
Feb 06, 2014 | Bernina Sewing Machines
I need a Huskylock 901 manual
You can find a manual for the huskylock 901 on website.
Oct 09, 2011 | Husqvarna Huskylock Computerized 910
I need information on how to oil my huskylock 905
Oil any and all moving parts with sewing machine oil. If you turn the handwheel, look to see which parts are moving and oil them.
Feb 22, 2010 | Husqvarna Huskylock Computerized 905
Huskylock 936 error code
This will also occur if the "needles" and "loopers" lock up as though threads are tangled and binding the machine. If needles and loopers move freely when manually turning the handwheel counter clockwise, you probably need to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page -
Good luck.
Nov 28, 2009 | Husqvarna Huskylock Computerized 936
Huskylock 936
If your machine is hard to turn you need to look for threads which are bunched up around moving parts or it needs oil badly. This, combined with skipping stitches, indicates a need for a technician to adjust the timing and generally service the machine.
May 18, 2008 | Husqvarna Huskylock Computerized 936
Sewing Machines Logo
388 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
