Question about Big Boss Oil-Less Fryer 8605
Mine did not come with the tongs to take the hot basket out, where can I get one
  • 16,736 Answers
My Whirlpool Duet dryer lint screen will not go back in after being cleaned. It sticks out about 1/2 inch more than usual. Please advise.
Something is lodged in the dryer in the way, grab a flashlight and some hot dog tongs and, well, I'm sure you know what comes next.
Mar 21, 2017 | Whirlpool Dryers
Turned it on and heard a sizzling noise, unplugged it and now my on/off switch will not move.
just keep it in longer mine does that at first if its still doing that its fried you just need to get a new one
Hope I could help (")>
Sep 14, 2013 | HAI Elite Tong 2" Flat Iron
Help lollipop stuck
Just Get Knife Stick It Inside Next To Lolipop and cut it out Or Try Rip the plastic off around it... =D
Feb 16, 2013 | Cats
What is a hair iron? The thought of ironing hair sounds very scary.
A hair iron (or hair tong) is a type of hair tool that uses heat to change the structure of the hair ie to straighten it or crimp it. They do get very hot but it's not as scary as it sounds.
Jan 10, 2013 | Health & Beauty
How much water do I use for the Salton hot basket? I do not have the instructions.
if it is the Cosmopolitan "Hot Basket" you put a tablespoon of water in the water hole. The opening is located on the cover of the "hot basket". This method is best for items made with grain such as : bagels, Italian or French bread, biscuits, Danish pastry, dinner rolls, hard rolls, yesterday's rolls. To keep these items hot, place the rack in the bottom of the hot basket lettering face up add 1 tablespoon of water to the water hole opening located on the cover of the" hot basket".
Jun 18, 2012 | Salton Vintage Hot Basket, Model Bh-5
How do you open an alessi pepper mill to refill it?
You will need:- Large cooking pot- Grinder- Tongs- Hot pads or oven mitts (mitts are recommended)- CautionPut the grinder into a large cooking pot. Fill the pot with water until the grinder is completely submerged. Make sure that the plastic parts of the grinder do not touch the bottom or sides of the pot. On the stove-top bring the water in the pot to a boil. Once the water is boiling turn off the heat. The grinder is now very hot and full of hot water so be careful not to burn yourself. Using tongs remove the grinder from the water and hold it upside down to drain most of the trapped water back into the pot. Now turn the grinder upright again to trap any remaining hot water. Using your hot pads or oven mitts grasp the glass part of the grinder in one hand and the plastic part with the other hand and pry them apart. Let both parts of the grinder dry completely then refill it and snap the plastic top back on. These make great grinders for other spices as well such as coriander. Enjoy!
Aug 09, 2011 | Coffee Makers & Espresso Machines
How do I change license plate light on a 2005 jeep grand cherokee
Remove the light cover on the tail gate. The easiest thing I found would probably work would be some rubber ended tongs (like test tube holder) and pull the bulb out. I removed all the plastic from the tail gate and poped the handle cover off (I would advise against that!) I replaced mine with LEDs so I won't do it again. But I'm almost %100 sure that it would come out with rubber grip tongs. Good luck!
Dec 18, 2010 | 2005 Jeep Grand Cherokee
How does it come apart for cleaning
The hot water did work for mine. Here is the solution I discovered:
After removing the food plunger and juicer cover: (1) Unscrew the 3 screws that hold the cutting blade plate in the center of the basket and lift off the cutting blade plate; (2) Unscrew the base counterclockwise (it will unscrew from the threaded center piece) and lift it up; (3) Lift off the basket and juice bowl. Now you can clean the basket and juice bowl.
To reassemble, reverse the process.
Sep 20, 2009 | Juicers
Bravetti pro 4 litre deep fryer model f1400b. used 3 times and whenever i use batter with like fish, put it in the basket, everything sticks to the bottom of the basket like glue. no matter what i try it...
Hi, this one is a bit tricky: you have to drop the basket first, hold on to one end of the fish without burning your fingers, and give the batter a minute - the whole piece will start to float when the batter starts to cook. You need to flip it over with tongs to cook it completely.
Sep 04, 2009 | Bravetti Kitchen Appliances - Others
Hi, i have marshmallow smeared on my car seat and i havent touched it as i would like to know the right way of cleaning it.could you please help me. robyn
i know how to fix it!!! all you need is a pair of tongs boiling water a towel and a possitive attitude! just boil the towel PLEASE USE THE TONGS to put the really hot towel on the seat over the fluff let it sit for a sec to let it warm up. then just scrub it off with said towel. :3
Jul 14, 2009 | Baby Gear
Big Boss Oil-Less Fryer 8605 Logo
280 people viewed this question
Top Big Boss Kitchen Appliances - Others Experts
Danny Kuhlmann
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Big Boss Kitchen Appliances - Other Expert? Answer questions, earn points and help others
