Question about Sony SDM-HS95 19" LCD Monitor
Programs launching to DVI-D instead of to HD15
Just recently, the Notepad program has begun launching to the monitor I don't use - the DVI-D one. How can I fix this?
Set the display properties to clone mode
Posted on Nov 02, 2008
I have a Hitachi 55hdt51M 55" plasma monitor/TV with no AVC75 controller. Can I operate this monitor/TV without a controller box vias some sort of direct hookup? The only input connection is labeled "in...
You can use either input to use the monitor as long as you have the correct cable. HD15 to DVI can be converted and so can HDMI to DVI. Only hold up is the type of DVI. There are three types and I cannot remember for sure the designation but I believe there is an I, S and a D. The device will have to be able to display in a matching format.
Jan 27, 2014 | Televison & Video
Does a de/db9 to dvi-d female adapter even exist? Is there a combination of adapters I might be able to use? I need an adapter with one female de/db9 to connect to my computer whose other end is a...
Looks like it does exist...
Are you sure its a DB9 and not an hd15?
Jun 11, 2011 | Televison & Video
I want to switch it my monitor from HD15 Mode to DVI on my VGC RB52
Assuming you have not already upgraded the system, you will need to add a video card with DVI output to your computer. You need a PCI-e x16 card and to make sure to either upgrade your power supply or choose a card that will not exceed the power supply's capacity. The original Power supply provided 305W (max.).
The alternative is to simply attach a DVI to VGA converter and stick with the on-board VGA only output but send it through the DVI port on the monitor.
I hope this helps.
(you should pay attention to heat issues if you add a video card; I've generally found that ATI cards run a bit cooler than nVidia cards for the same generation/performance.)
Mar 02, 2010 | Sony VAIO PC Desktop
Vga lead will not fit tower
Try turning it around. If it still doesn't fit, you may need a DVI to VGA adapter.
Aug 05, 2009 | Xerox Computers & Internet
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
My documents download into notepad as gibberish
Try un-installing the adobe acrobat reader program and reinstalling it. If you have XP it is in ADD/REMOVE programs in the control panel. If you have Vista it is in Programs and features in the control panel. Then go to adobe's website and download the newest FREE Acrobat Reader. Make sure you un-check to get the FREE toolbar, as they are usually junk and cause more problems then they help.
Nov 25, 2008 | HP Pavilion dv6000z Notebook
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Jul 27, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Sony SDM-HS95 19" LCD Monitor Logo
87 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
