Question about HP Deskjet 3845 InkJet Printer
Printing and bottom of some lines are cut off.
The bottom of a line does not print. I replaced cartridges and it still has a problem. How can I fix it. I replaced both cartridges and am using HP cartridges.
    President:
  • HP Master
  • 1,447 Answers
It is the problem printer prasher cartridge head is not position
Posted on Jul 17, 2009
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
Printing with horizontal dark lines
Did the dark lines start after the change? If so, maybe the drum on one of the cartridges is damaged. (Since you mentioned dark, I'd suspect the black cartridge.) Try replacing cartridges.
If that doesn't fix it, you can send it in for repair if it's under warranty. If it's outside warranty, I'd probably just replace it, unless you want to learn a lot about the innards of a laser printer.
Apr 21, 2015 | Dell 3110cn Laser Printer
Alignment off
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please try this approach:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page and aligning your print cartridges. Try to print a document again to verify that the problem is fixed.
Dec 11, 2011 | Lexmark X7170 All-In-One InkJet Printer
Canon Printer - Pixma 5000 Trying to print out pages of text. The text is coming out with a line printing normally - then a block of text / lines missing completely - then tops of line or bottom of line...
pull out the black cartridge then get a tissue paper try pressing the nozzle again the tissue paper but not so hard then release look for the straight line that appear on the tissue paper if it is not change it
Aug 07, 2011 | Canon Office Equipment & Supplies
Lines in printing
...maybe its time to replace fuser fixing film!?
Nov 10, 2009 | HP LaserJet 1020 Printer
Cutting off lines and bottoms of letters
Try replacing the ink cartridge or putting tape on the cartridge where the ink comes out and rip it off so it doesnt block some of the printing.
Jul 21, 2009 | Office Equipment & Supplies
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Leximark P915
There is very likely a few plugged print head on your black cartridge. The printer or its software should have some maintenance options to do a cleaning.
Otherwise, you would need to try a new cartridge to see if the problem reproduces itself or take a look inside. There are a few possibilities.
#1: Some dirt/dust/hair/etc... has gotten stuck under the print carriage and is blocking certain print heads, unlikely as you would get some spotching and messy prints.
#2: The contacts behind the cartridge either on the cartridge or in the carriage are dirty and blocked so the signal is not getting to some of the print heads.
#3: The trailing cable going from the engine board to the carriage is damaged and is causing some printheads not to fire.
#4: The engine board is faulty, unlikely since the printer still seems to print well.
The short answer is that it's not economical to repair the printer further than replacing the cartridge. If you're fairly certain the cartridge is clean or that a new cartridge won't or hasn't fixed the problem then it's time to replace your printer.
Have fun!
Aug 18, 2008 | Epson Stylus Color 440 InkJet Printer
Black ink from new cartridge is missing lines
Try doing nozzle cleaning, hope fully this flushes the air bubbles trapped in the cartridges. Or try using this template which sometimes flushes out the inks.
Jul 06, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Print result at 1st line ok..2nd line become blur..its alternate till end of printing
Replace the ink cartridge.
The cartridge is so wide that it can print 2 lines at a time, and the upper part of it is probably partially clogged. That's why every 2'nd line is blurred, and the rest is ok.
Jan 17, 2008 | Office Equipment & Supplies
HP Deskjet 3845 InkJet Printer Logo
130 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
