Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
Top rack frosting bottom of freezer won't freeze ice cream
I just defrosted my freezer and the top rack frost up and the bottom won't even keep ice cream frozen any solutions?
  • Frigidaire Master
  • 3,361 Answers
Your door seals are leaking air.
Posted on Jul 17, 2009
    New Friend:
Dear Sir,
Our nee 237 pcs 280 liter Freeze, Please confirm me your product in our following specification :
Freeze
Feature :
  • Microprocessor control with digital display system with up right appearance.
  • The system ensure a constraint inner cabinet temperature with 20 C - 80 C
  • Unit should be CFC free and high efficiency compressor with low noise
  • Epoxy coated scratch resistance exterior
  • Seam less ABS/SS interior for easy cleaning & decontamination
  • Up right appearance with glass door
  • Unit should have forced air cooling system to make inner temperature stable and uniform
  • Transparent glass door with in inner lighting system and lockable caster design
  • Should be safety lock system presents unauthorized access
  • Inner battery back up system for minimum 72 hours in case of power failure
  • Both Audible and visible alarm for over temperature, power failure, sensor error, door opening low voltage
Specification
specification :
Capacity : Minimum 280 liter or more
Adjustable set temperature : +2 degree C + 8 degree C
Temperature : 0.1 degree C
Shelve quantity : Minimum 4 or more
Power : 220 -240 VAC, 50Hz
Warranty period :
3 (three) years full including, repairing and servicing free of cost for all items from the date of installation.
Quality Stan dared : CE/US-FDA/JIS certified, Certificate of the offered item must submitted with the offer.
With best
Mohammad Ali
M/S Hossain sakik International BD.
Email : am.scientific@yahoo.com
Posted on May 10, 2013
Top shelves in freezer not freezing food. Also no ice from ice maker. Seems cold air has stopped coming out of top vent
We had the same problem with our refrigerator just yesterday. Defrosting (even tho frost-free) cleared up the airflow problem-- If it's frost-free, when it defrosts enough to allow air flow, the automatic defrost can take over. Cause was stored food blocking the vent between the freezer and lower part of fridge.
Mar 02, 2013 | Freezers
My freezer doesn't seem to be freezing as well as it has in the past. somethings are frozen hard but ice cream isn't as solid as it should be
Try this... unplug...
take everything out and defrost the freezer
(go get a couple bags of ice and a big clean garbage can so you can keep the food cold)
you can defrost the freezer faster with a hair dryer
when you finish turn t'stat to high setting... put all food back in and dont overload and dont block any air vents (if they are located at top dont overlaod)
plugg in wait 24 hrs...
if you dont notice a difference let me know...
hope this was helpful
Mar 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My AEG Arctis freezer is not freezing at the correct temperature and seems to stick on -11 even if I put the fast freeze on.I have turned it off for 24 hours and on again but it still does not hold the...
The freezer is probably in need of defrosting. This usually occurs when the freezer has been over packed. It needs to be able to ahve air flow through it, there are holes in the back of the freezer and a defrosting element at the top and they need to be clear in order to keep it frost free. It happend to me and we called an engineer out. solved it by using hair dryer to defrost it.
Oct 05, 2009 | AEG 10.35 cu. ft. / 293 liter Upright...
Upright freezer
If it has a fan in the freezer it need to be running to circulate the cold air.
If the coils are not icing up evenly from top to bottom you have a system low on freon.
The light frosting is normal.
A model number would really help to troubleshoot the problem.
Sep 19, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Its freezing roun the top and not the bottom?
is this a chest freezer? Thick frost around top? try defrosting unit. DO NOT scrape the ice. Very important to remove drain plug to remove water or frost will very rapidly redeposit
Jul 13, 2009 | General Electric Chest Freezer FCM5SU
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Model sku fu25w 24.7 cu. ft. freezes water
I have a Woos's frost free freezer and it keeps getting ice in the bottom what can I do to stop this?
Dec 29, 2008 | Woods Upright Freezer MU07W
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
372 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
