I have a toshiba tv model#65h80 seial#58440189 classic#tac0071 power keeps going out i have to unplug it to reset red power button bink when it goes out can not turn the red button off with remote when this happens
  • andiandi Jul 17, 2009
    thank you so much for your time you where a big help to me
    yes it was very helpful he answered my questions
  • 3,741 Answers
Ita a circuit board problem in the tv and it needs to be checked and the faulty components on board needs to be replaced. thanks.
Posted on Jul 17, 2009
  • charlymonty Jul 17, 2009
    a local tv repair technician near to your place.or at new tv shops they also have technicians who deals in reparing tv and other electronics.
    this will help.
    thanks.
    please do rate the solution.thank you for using fixya.keep updated
Disassemble Toshiba 65H80 tv
No, cabinet is glued and screwed---entire front screen can be removed and the mirror inside also(be very careful with that) as they are the two things that get damaged most when transporting a set.
Moving a long ways or just across town?
Apr 22, 2012 | Toshiba 65H80 65" Rear Projection...
When we try to turn on the tv (toshiba model 32A43) it makes the sound of turning on then off and the screen stays black and a red light by the power button keeps binking
You're either losing high voltage or power supply is not producing the horizontal drive signal, Check for 130v on the collector of the horizontal output transistor, if you're missing your voltage, you have a power supply problem. If voltage is too high you have something open in the power supply such as a low value resistor. If its low, something is shorted in power supply, possibly voltage regulator ic.
Jul 31, 2011 | Toshiba 32A43 32" TV
There is no picture or sound
check your lamp, if lamp has been replaced then re-set the lamp timer, if you hear a clicking or buzzing and no picture is probable that you could have a ballast problem. I'd check the lamp first though.
Apr 13, 2010 | Toshiba 65H80 65" Rear Projection...
My Toshiba 65H80 has red convergence problem. It
You may have cooked your new IC's
I am working on the exact same problem with the same symptoms. Make sure the tv is unplugged for at least 5 minutes before poking around. The power cord can be unplugged from the power board and removed to keep anyone from plugging it in while you are working on it.
Check the output resistors that are beneath the heat sink on the left side of the board. There are also fusible resistors, like #7711, on that side.
Check fuse 853 on the Power board. This is the board on the left when viewed from the back of the TV. You can remove both boards in the carrier by carefully unplugging all connectors, noting their locations and routing.
To remove the high voltage wires from the splitter, mark them for position then grasp the boot and turn counter-clockwise about 10 degrees to unlock them and then pull up while holding the High voltage splitter. The small high voltage wire can be removed from the flyback transformer by pulling hard while holding the flyback.
STK392-110 can be replaced with STK392-120, STK392-180, STK394-160.
I have found most of the parts at newark.com. Also check out this site for some very good info: http://www.hometheatershack.com/forums/diy-repair-maintenance/5600-crt-based-rptv-convergence-repairs.html
btw: I am not affiliated in any way.
Make sure that while you have the boards out you look for any bad solder connections. A lot of problems arise or return because of this.
I hope this helps, I have been doing a lot of searching to get this info and hope it helps you.
Too many people want to trickle the info and pretend they are giving you gold. A few hobbyists or people that can't afford to pay $300+ for repairs are not going to hurt their business.
Be safe and share knowlege freely!
Jan 31, 2010 | Toshiba 65H80 65" Rear Projection...
Toshiba tz43v61 TV just died. No red light.
does it have a power strip on the tv stand? if so plug the tv into a wall socket.my power strip went bad and the reset button did not work
Jul 17, 2009 | Toshiba TZ43V61 43" Rear Projection...
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
