Question about Belkin TuneTalk
Sometimes got problems with my recordings, sounds like its swallowing up/skipping what im recording. any idea? vibrations? loud volume? cheers
  • 123 Answers
Go to mobile center
Posted on Jul 17, 2009
Tascam 488 Tape Recorder
Have you tried playing the tape in another device? Adjusting the recording volume if that is an option? Look for the user manual pdf online and also try a brand new or different brand tape to ensure that is not the problem.
Nov 16, 2013 | Tascam Audio Players & Recorders
LOUD HUMMING NOISE COMING FROM SPEAKERS
Could do with a service.
Check the turntable motor and drive plus check the cartridge and signal wiring.
Sep 14, 2017 | Wurlitzer Jukebox CD Player
Got record and it is not loud. never had any problems with other vinyl records sound quality. I want the songs to be converted to MP3 but the sound on them is so flat. other records I have converted sound...
Hi, maybe the record is worn and that's why the sound is low. By using third party audio editing software (i.e. cool edit [paid] or audacity [free]) you can improve quality and volume of digital sound.
Aug 11, 2011 | ION Audio Vinyl Recording Turntable
My PL120 turntable purchase new skips often and will hardly work with music played at a loud volume
The first problem could be the stylus needs cleaning. Please shine some light on the stylus ( needle ) and see if it has picked up dirt from the record groove. This will prevent the stylus from tracking the song properly. Clean using a fine brush in the direction in which the stylus passes the record groove i.e from back of the pick up arm to front- NEVER SIDEWAYS.
Next check the counterweight adjustment at the back of the Pick up arm. The tracking force should be between 1.5 to 3 grams depending on the brand of the cartridge. What ever be the chosen weight the antiskating knob should also be set to the same number.
The skipping can also be because of heavy bass vibration traveling up the body of the Turntable.Good turntables have a floating suspension to prevent this. The tuntable platter will be suspended on springs.You can place it on a rubber Matt or move it away from the speakers ,esp: sub woofers.
Apr 06, 2011 | Audio Technica AT-PL120 Turntable
Arm's Weight
Not by design.
Tracking Force and anti-skate are preset and unfortunately not adjustable in many modern turntables . You want to be cautious with modifying it if only a couple of your records skip.
If you DO decide to try modifying it consder that the tracking force is in the probable range of 2-4 grams. In the old prehistoric days before T'Ts had adustable tracking and antiskate we would place a dime or penny on top of the cartridge shell to assert the stylus into the groove. THAT is a bad idea unless excessive record and stylus wear is unimportant to you.
Is there anything that might contribute to skipping (not level, scratches, warps, environmental vibrations, loud speakers nearby)?
Apr 01, 2010 | Audio Technica AT-PL50 Turntable
How do i stop tha tracks from skipping, because while im recording tha audio tracks seem to skip
Depending on whether you are using recording software and what kind you are using you are experiencing what is known as latency. It happens when your computer is not fast enough to keep up with what you are recording. More RAM sometimes helps. Sometimes it is just a simple adjustment. It is too long a subject to go into here. Try looking at Audacity which is freeware. There is a good explanation on their site. Also, I would recommend Asio4all. Hope this helps.
Oct 21, 2009 | M-Audio Producer USB Microphone with...
Ilo DVDR05 Vibration and loud humming noise
i experienced that problem before.one cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
May 17, 2009 | iLO DVDR05 DVD Recorder
Ion ittusb turntable interference
Please describe the conditions under which the noise happens. Is it always the same place? Whic is it - static or some other kind of interference? Read the following. If you're using high speaker volume to monitor while recording you could experiment with identifying it as the casue by cranking it up to see if you can make it worse.
As with any turntable the following advice for this one will apply:
The tonearm setup is critical for proper tracking. Do it again with extreme care if mistracking is your problem.
I found one model online and a review with some sample of music. Quite interesting...
http://www.everythingusb.com/ion_ttusb10_usb_turntable_13231.html
The author complained about some things that clearly mark him as a stranger to finer turntables. Complaining about having to assemble and position the 'rubber band', aka the drivebelt, and the tonearm counterweight shows that he underestimates the precision required for a mechanism to rotate at a constant precise speed while properly tracking the microscopic undulations of the groove without skipping into the air or gouging it to death.
Some basics when recording from a turntable...
1) Place the turntable as far from speakers as possible on a solid surface that you will not touch during the recording
2) Keep the volume low enough that airborne sounds don't cause mistracking of the stylus *
3) Avoid anything that will cause vibration or movement of the turntable. (Tip toe)
* If you have a subwoofer, turn it off.
Some advice after reading the article: don't try to save recording time by playing the discs at 45rpm. The best tracking of the disc and recording of the minute details in the grooves will be at the nativespeed of the recording. Digital manipulation later only gloms up the accuracy you probably want.
In general, the fewer the conversions steps in the analog domain, the better; and the fewer the bit rate conversions in the digital domain, the better.
Mar 26, 2009 | ION Audio Vinyl Recording Turntable
AUDIO
Hey Tex
You are on the right track, sounds like a noisy volume control. Can often be repaired with a squirt of cleaner spray into the potentiometer assembly.But I suggest you use crc2-26 contact lubricant spray, not silicone spray which is a great materials lubricant, but not electrical. Worst case, the Vol Potentiometer, may have to be replaced. Go for the CRC first and see how it goes. Good Luck, happy FixYa
regards
Graeme
Mar 05, 2008 | Audio Players & Recorders
Intermitent audio
I had that happen before, one problem was my car had bad shocks or i hit a pothole in the road. The second time i had the volume up so loud the bass wass thumping the floor and it skips the CD. My question is, how lowd is the thign turned up? :P Some CD players load the data into a memory and then it plays from the memory till it needs more info. It maybe that the unit is not stable or the CD is not balanced right so it cant read the info at a consistant speed. The music maybe playing faster then it can read because of the vibrations. Is the disk clean? i know this may sound dumb but it is easy to over look. If the surface of the data side is so scratched up it may have problems reading the data quickly enough. Sometimes the coating can fall of the disk if you hold it in the light you can sometimes see spots threw the disk where the foil has been chipped off. The CD player could have a focus problem also, it could be damaged in shipping or have been dropped and it cant focus properly on the data. Do you have any other disks to try? a new one? one you never play?
Apr 04, 2006 | Philips CDR785 3-Disc CD Recorder
Belkin TuneTalk Logo
90 people viewed this question
Top Belkin Audio Players & Recorders Experts
woodzowl307
Renee Knafel-Bullock
Are you a Belkin Audio Player and Recorder Expert? Answer questions, earn points and help others
