Question about Craftsman Garden
Engine runs rough. I have changed spark plugs,
Engine runs rough. I have changed spark plugs, fuel filter and gas. Still same problem
    New Friend:
  • 93 Answers
Check Flywheel Key, Carb Adjustment or if older engine also valve job.
Posted on Sep 15, 2009
My 99 navigator 5.4 engine runs rough when accelerating
Check fuel filter and air,could be tune up,bad wires.
Jan 21, 2015 | 1999 Lincoln Navigator
Why does the engine of my 1998 Chevy Cavalier z24 start rough when cold?
It sounds like your fuel filter is clogged, or the fuel pump is failing. I would change the filter first and see if that does it.
Sep 07, 2014 | 1998 Chevrolet Cavalier
2000 s-type 3.0 no check engin light on run rough ?
try changing fuel filter it might work
Jun 08, 2012 | 2000 Jaguar S-Type
My engine lights flashes and run roughly like sputtery what could be the problem
Hi:
Usually, the only thing that will make the check engine light flash, is a cylinder misfire. You need to have your vehicle's computer scanned, to see what tripped the code. Most autoparts stores will do this for free. You might have a bad distributor cap, ignition module or related part, but the free code scan will point you in the right direction!
Sep 30, 2010 | 2000 Ford Expedition
1996 chevy cobolt 6 cyl. "engine power reduced" idols extremly rough shaking entire engine. When pushing on gas pedal car will sputter acting like it wants to die.
It sounds like you have a fuel issue or spark issue. Pull your spark plugs and see how they look. If they look fine then test the fuel pump. You could try to run to fuel system cleaner through the fuel system and see if there is an improvement in idle. Could be any of the following problems,
coil
spark plugs
spark plug wires
fuel filter
fuel pump
injectors
air filter
Check the easy stuff like plugs, wires fuel pump and air filter first.
Mar 03, 2010 | 2009 Chevrolet Cobalt
Engine runs extremely rough, seems to be fuel related, new fuel pump & filter installed, pressure good, run 2 bottles of injector cleaner through. Can't get to stay running under load. 1998, chev....
Have you changed the plugs, if any are fouled out or if any are worn, it takes more to fire it under load and may be spark knocking because one of the plugs can't fire off all the gas and cause it to skip or idle rough.
Jan 18, 2010 | 1998 Chevrolet K1500
ENGINE IDLES ROUGH, BUT RUNS FINE WHILE DRIVING. My car is a 1995 Buick Regal Gran Sport with the 3800 series motor with 212000 miles. The rough idle tarted after driving through some muddy and wet roads
go the cheapest route. replace fuel filter and add SEAFOAM to tank of premiun fuel. replace filter before 500 miles. then add SEAFOAM to gas every 3000 miles to keep lines.engine,fuel pump, and emissions systems clean, ETHANOL problem number 3000
Aug 29, 2009 | 1995 Buick Regal
Start and stop
Top candidates for this problem are:
Clogged Fuel filter
Faulty Fuel pump
Clogged fuel injectors
Dirty / worn spark plugs
Of these, only the clogged fuel injectors are likely to respond to a gas tank additive, and even then you need to get the right kind of additive.
If your fuel filter has not been changed in a while (couple years), start with this. It is fairly easy to change. The fuel filter is under the car near the the driver's side rear door.
If this problem started "suddenly," then the fuel pump might be the culprit.
Fuel injector / spark plug issues are not likely to stop the engine right away, but would tend to cause it to miss cylinders, idle rough, or start rough.
Mar 08, 2009 | 1985 Oldsmobile 98
Engine running rough
hey
As in "rough" could you be more descriptive.
i.e.
what does it do when your driving?
is it sparking on all cylinders?
any knocking in the engine?
Damien
Aug 22, 2008 | 1999 Ford Expedition
Garden Logo
321 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
