Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
I have a Saeco Incanto Sirius that I purchased refurbished. The display went blank one morning and now nothing works. It seems as though the unit is not getting power. Any suggestions? Thanks
    President:
  • 1,618 Answers
It could be that the main fuse for the machine is damaged or the CPU board is damaged or the capacitor, which is located under the pump is damaged.
Posted on Oct 07, 2009
Message door is opened Saeco Sirius
i've refurbished 3 of these just last month. this is a pain to fix when it happens imho. get your newelectronx 102 and grab the oval screwdriver. we need to get our hands dirty.
pull out the brew group and you should see a spring directly above the door. somewhere above the brew group funnel. use a paper clip or reach a flat head for the tool kit in there and remove coffee ground that is causing this problem. unjam that micro switch sensor and viola your this message should disappear.
Jul 31, 2015 | Saeco 00034 Incanto Sirius Super Automatic...
I have a Saeco Incanto S-class sirius machine. Message displayed, "Brew Group Blocked", so I purchased a new Brew Group Unit, when I installed it, got the same message. when turned on, I can...
Brew group blocked is normally displayed when there is no water flowing through the brew unit. Remove the brew unit and use a small screwdriver(make sure machine is off and cooled), then gently lift up on cross section fitting on white plastic valve inside the machine, if water flows out it works, now we will plug in machine keep brew unit out and turn it on and press fitting in again, if water flows and pump kicks in and water flows out from valve and not under machine you are good, The coffee grind might be too fine and needs to be adjusted to coarser.
Jun 28, 2011 | Saeco Incanto Sirius Fully Automatic...
My saeco Incanto Sirius machine never works. It seems the touch screen is not working. Any ideas?
I had the same problem with my one when it was new, the dealer admitted they know about some faulty touch screen units and replaced mine free of charge. Credits to the Saeco dealer in Reykjavik, he did so with no obligation, my machine had warranty somewhere else in the world, good will.
Feb 07, 2011 | Saeco Incanto Sirius Fully Automatic...
Saeco Incanto sirius has a blank screen. All the buttons work but the screen is blank
If it not burn out by a short, probably the flat wir conector is loose or moved out. You should try to force the connector back in place. Good luck.
Please remember to vote for this answer thanks
Feb 17, 2010 | Saeco Incanto Coffee Maker
Saeco S-class Incanto Sirius brew unit stuck
Try running the clean cycle again, that sometimes will help the machine to reset.
Sep 15, 2009 | Saeco Incanto Sirius Fully Automatic...
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
SAECO Incanto Sirius Brew Group
When you remove brew unit look on the back you will notice a small latch near the top, make sure it is in the up position.
Feb 03, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Odea Giro - Watertank
Yes that is perfectly normal. It has to have enough for a long coffee or steam. So it always has some to spare in the tank.
Dec 02, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco incanto sirius
It can be the touch board or the "water turbine" in the machine
May 25, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
332 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
