Motorcycles Logo
Brian Ballschmieder Posted on May 15, 2016
What is the proper front tire size for a Kawasaki voyager 1200 1986
  • Brian Ballschmieder May 15, 2016
    Front tire size for Kawasaki voyage r 1986
Rw Thomas
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on May 17, 2016
Rw Thomas
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
4112
Points
59
1 Related Answer
Anonymous
  • 47 Answers
  • Posted on Jun 28, 2011
SOURCE: what is the size of the allen wrench do I need to
it is metric and should be in the toolkit under the seat
2answers
What size tires
The stock (OEM) size for your car tyres are
215/65/R15
If you dont understand this. Any tyre seller/mechanic will.
I have a 1998 Plymouth Voyager and I need to put on studded tires. It currently has tires with this number: P215/65R15. What size of sudded tire should I put on? Is there a range available or only one...
If i were you i would put the same size studded tire on it as you have on it now.. if you change the tire size it will throw your speed ometer off.. they make them in most every size for all vehicles... i would definately stick with the P215/65R15s. hope this helps
Im buying a chrysler grand voyager but need to perchase alloy wheels but dont know the size of the wheels can you help please.
On the tire there will be a series of letters and numbers that is the tire size, for example P235-15-75. The middle number is the size of your rim. You should be able to get your new rims from this or even if you go in with the whole tire size number they should be able to fix you up. Hope this helps.
2helpful
2answers
Need to know the tire size...
There are 2 choices for the Standard Plymouth Voyager:
195/75/14 or 205/70/14
5helpful
2answers
What is the proper tire size for a 2000 caravan
If you want to know the correct tire size for your vehicle. Open the drivers door and look on the edge of the door under the latch. You should find a data plate that will tell you size of tire for your van and proper air pressure for front and back tires.
1990 Kawasaki ZXR 750 maximum tire sizes that will fit
STAY with the factory recommendations!! Too much bigger tires will adversely affect the handling... and not give you really any benefits.. IF YOU INSIST.. only go to the smallest NEXT available size - PERIOD!!!
1helpful
2answers
Gpz 1100
36 front...42 rear
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
