Question about ASUS P5LD2-VM Motherboard
Cannot find anything for my lan setting
I cannot connect Via my lan, i dont even see my settting...i went into device manager and never found it there, i am currently connect via wireless card
  • jamdon_1 Nov 18, 2007
    Yes i have, it is enabled in my bios, checked it twice
    yes i have, lan is enabled in my bios
  • 205 Answers
Have you booted up in the BIOS to see if the on board lan is enabled?
Posted on Nov 18, 2007
  • ohiotom Nov 18, 2007
    OK, how about the driver software? Most motherboards come with driver software for on board devices like lan and sound. Have those drivers been installed?
I would like to set up a password for my router.
Link to user guide
Page 9 Descripts setting the wireless secuirty. Make sure you do WPA2 with PSK this is the most secure.
Page 17 Administration > Management describes changing the the router management password. Also a very good idea. Change it to HTTPS only and disable remote management (Via wireless) This will ensure the management configuration is encryted and only accessable via a local lan connection.
Comment if you have additional questions and please rate the solution if you found it helpful.
Oct 27, 2011 | Linksys Wireless-G WRT54G Router
I am trying to connect my toshiba a15-5129 in my house it will not connect to broadband
Hi, we have two ways to connect to broadband, via wired or wireless, at the device manager please do check if the LAN drivers are enabled, if enabled, via wired connection, simply put the RJ45 jack from LAN port of your router to LAN port of your notebook, if configuration is already set in your Router LAN, it will just automatically connect. If connecting via wireless press wifi button to activate wifi connection then windows will pop for your access credentials. simply put the password for your connection once the name of the site displayed.
Jun 20, 2011 | Toshiba Satellite A15-S129 Notebook
My ports and my on board LAN are not working my motherboard is ECS PV4MM2..What shoulbe the proble and how can I resolve it.Yahks if you would respond immediately on my problem
Go to Device manager By following this steps
  1. On the desktop right-click on My Computer and click Properties or open the Control Panel and double-click the System icon.
  2. In the System Properties window click the Hardware tab.
  3. In the Hardware tab click the Device Manager button.
Then on left side Search for Yellow question mark on Ethernet controller if it occurs than the problem is that you have to reinstall your LAN drivers which can be Downloaded here
And If there is no Yellow Question Mark then you have to bring a LAN card and insert in PCI Express Slot.
Jan 28, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
I have zyxel p-600 series router and i managed to connect to internet via cable (wired).then internet works on my ubuntu 10.04 but only when i write sudo dhclient in terminal. then internet works but i...
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Jun 04, 2017 | Zyxel Prestige 600WH Wireless Router...
My crystal eye web cam is completely gone from my computer.
ACER Aspire 5737Z – Acer Crystal Eye WebCam camera no found
I had the symptom where ‘no camera found’ and the device not showing in device manager (unless you expose hidden devices, but was visable via non present hardware (exposed via system variable
Solution – Disable and Enable USB Controllers
1. From Device Manager
2. Right click and uninstall the Standard Enhanced the Universal Serial Bus controllers -> Standard Enhanced PCI to USB Host Controller – do this for both via right click - uninstall.
3. Right Click <YourSystemName> from the top of Device Manager, Click Scan for Hardware Changes.
4. Your Acer Crystal Webcam should now back under Imaging Devices, and working again!
5. Strange but seems to fix it, good luck!
I also pressed the top of the laptop screen to the left and right of the camera at around the same time. Not sure if something clicked back into place, either way above is a simple thing to try... Hope this helps.
Jan 22, 2010 | Acer Aspire 5610-4648 Notebook
I found I needed a USB/Ethernet adaptor in order to connect my new broadband and purchased an ASIX AX88772A vai your product A31GY from Maplins. I'm having trouble in that the Broadband set up refuses to...
I allowed Windows Update to search for the right driver. This took a long time - I'd tried earlier but evidently hadn't let it run for long enough. It located and loaded a driver and everything was then fine: the ethernet connection (via adaptor) 'went live', my new broadband set-up software recognised it and proceeded sussessfully from there.
I assume that the device manager on my PC was correctly identifying corrupt drivers on the small CD supplied with the adaptor and that I'd managed to find uncorrupted ones on the internet via Windows Update.
Robin Lovelock
Dec 09, 2009 | Computers & Internet
Cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
Sep 03, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Wireless internet connection not found
i need driver for my laptop by name vostro 1500 ( minicard 1390
May 01, 2009 | Gateway Computers & Internet
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Gateway 505GR not showing LAN line for internet
assuming it's XP,right click my computer>properties>hardware tab>device manager, then look down list for network adapters, if its there click the '+' sign, then right click on the network adapter and select uninstall.
Restart pc and the network card will be found and the driver automatically installed.
It should now be in network connections, if not reply back
Aug 15, 2008 | Gateway 505GR PC Desktop
ASUS P5LD2-VM Motherboard Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
