Question about Lexmark T640 Laser Printer
T640 gives 242.10 error no paper jam found does not happen all the time I open tray 2 , close and hit check works will happen from tray 2 only
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Lexmark Expert
  • 217 Answers
Hi, most possible cause are worn rubbers tires in the papertray. You'll have to replace them. Partnumber is 40X0070. For now you can try to take the off and mount them inside out.
Good luck, Gerrit Jan
Posted on Jul 22, 2009
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
Hi, my lexmark T640 is saying 202.06 paper jam, check rear door. i have opened it and there is no jam, there is no paper anywhere and have pulled all the trays out and there is no jam. what do you suggest?
This jam is refering to back door, jam in fuser (hot bit) Double check no paper is wraped around fuser rollers.
These machines have a fuser at rear if you look at he fuser from the back, on it you will see, two thick fuser rollers (ones rubber), paper runs threw these then it hits a little black switch (your machine thinks this switch is activated) and then a series(3,4) of small rubber exit rollers, this switch (between middle and left) can get damaged it also likely that a piece of paper is concertinaed in fuser.
Oct 20, 2010 | Lexmark T640 Laser Printer
Error 077-900, what does that mean?
this error indicate paper jam at registration unit, to clean:
1. remove paper tray
2. open fron cover
3. remove jammed paper gently without tearing it
4. check if there are any creased paper sheets in tray, remove if any
5. check paper path if free from debris and any leftover paper tears/fragments
6. close front cover
7. insert back paper tray
If this advice did not solve your problem, please do not hesitate to follow this thread and I will forward further procedure how to check sensor and path.
Aug 12, 2010 | Dell 5100cn Laser Printer
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
HP 4200 printer paper jam. No paper is jammed
OK, if the printer says jam but no paper inside and prints after you open and close the cover the paper likely never made it out of the tray. Or the machine thinks the page never made it out of the machine.
As far as input check your rollers 1 in the tray and the pick up roller in the machine if you don't have alot of pages on the machine these likely OK.
Next (and this I have found often) check the paper back stop in the tray. This is the guide to set the length of paper. If it is set just a little long the roller cannot catch the edge of the paper. Sometimes the teeth the guide sets in are broken or worn.
The output would be the sensor in the fuser replace fuser.
Hope this helps
Feb 19, 2009 | HP LaserJet 4200 Printer
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
Resetting PaperPort after paper jam
I found the solution to this problem. Whenever the paper jammed in the feed tray, I was pulling the jammed paper out without opening the door of the feed tray. Apparently, PaperPort gets confused and does not know how to proceed. Now when I get a paper jam, I open the door of the feed tray, take out the paper, click on the paper jam error message in PaperPort, reset the paper in the feed tray, and then hit "scan." Works like a charm.
Sep 30, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Lexmark T640 Laser Printer Logo
2,483 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
