Question about HP Color LaserJet 2600n Printer
Printer will not print documents on a network server I can print documents on a different printer in the network
    President:
  • HP Master
  • 1,447 Answers
It is the problem printer driver setup correctly then configure your ip address problem solve
Posted on Jul 17, 2009
Can I wirelessly network my hp pec 1350 with a belkin wireless g all in one print server
The Belkin Wireless G All-In-One Print Server lets you easily add an all-in-one printer to your wireless or wired network. It features 802.11g technology that makes sending print jobs faster than ever, and includes a memory buffer that handles your graphic jobs effortlessly. The Print Server is so easy to install that you'll be printing in minutes. Simply connect your Print Server to your Belkin Wireless Router and run the Belkin Easy Installation CD. Next, attach your USB printer to the Print Server and load yourprinter drivers onto your computer. You are now free to print, scan, fax and readcard media* wirelessly from around the home or office. The Print Server also works flawlessly with wired networks through its integrated Ethernet port. Compatible with most USB, network-ready printers, the Wireless G All-In-One Print Server from Belkin delivers even your most data-intensive print jobs with maximum speed and reliability.
*If your all-in-one device has a card-reader slot.
Instructions:http://www.belkin.com/pyramid/documents/external/F1UP0002_EN_QIG.pdf
Nov 21, 2012 | HP Psc 1350 All In One Printer Scanner...
I need to get a wpa passphrase how do i get 1
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
My printer prints email etc. but will not print anything from my computer...example: word documents
I assume you mean that you can print from Outlook or other e-mail program (Outlook Express, LiveMail, Thunderbird). Are you reading your e-mail on the same computer that can't print Word documents?
If yes, one thing to try is to change the font on the Word document. For some reason, certain fonts just do not work. (Most often it is an issue with a document (or template) created on a different computer (or before upgrading the OS) and the font info gets scrambled in the transfer.) Just select all (control-A or Edit, Select All) and choose a new font. If the document has multiple fonts, do not use select all but highlight the sections separately and change the font.
If it is a different computer, check that the network is active and that all the correct drivers are installed. (One thing to check is a Universal Print Driver (UPD) software needs both the 32 and 64 bit drivers if the network has a mix of OS's. This comes up when the printer is attached to one computer and it serves as the print server.)
Apr 26, 2010 | HP PSC 2175 All-In-One InkJet Printer
I recently loaded windows 7 and now I cannot print word documents through the print server. I can if I connect direct to the printer. excel and powerpoint print normal through the print server. Is their a...
Start > Devices & Printers > Add a Printer > Add a network, wireless or Bluetooth printer
> The printer I want isn't listed (unless it is!) > Add a printer using a TCP/IP address or hostname
> Device Type = Autodetect / Hostname or IP address: 192.168.XXX.XXX (The 1260's IP assigned by
your router - make it a static IP beforehand) / Port name: [the autofill IP is fine] > Additional port
information required = Standard "Network Print Server (2 ports - USB)" > Select the driver for the printer
you want to use...
Once the install is complete go to the Devices and Printers screen and click on the new printer.
Click Customize your Printer, change the name if you prefer and then on the ports tab. Mine is
set to Protocol "Raw", Port Number 9100, Community Name "public". The only other thing I may be
doing differently is that I have set the printer to auto-show the print preview before printing.
Yes, its an additional click but it seemed to have made all the difference in my case. It also
gives you the chance to correct something like printing a second page with just a header URL, etc.
I realize that time is a luxury and not everyone has a lot of it, especially for trivial tasks
like addressing antiquated equipment compatibility issues after an upgrade, but I firmly believe
if you say can't enough, you WON'T. But for those who enjoy a challenge occasionally I hope this
points you in the right direction. Good luck
Jan 10, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Have a HP Laserjet P2015X. Documents will not print unless we turn the printer off and then turn on again....then a few minutes later document will print. This was happening sparodically for a while,...
to be sure about your printer try to print something directly from any PC. If all is OK then ask your system administrator to check Network. if problem persist again use Web Jet admin to update printer firmware. WJA is a free HP software for network HP printers - very helpfull i think
Sep 30, 2009 | HP LaserJet™ P2015X Printer
Can HP 1410 printer support LAN.
HP 1410 is not a network printer. If you want network printing, you must purchase a printer that features network printing.
You can designate a pc to act as network server and plug printer into that server, and then print from another computer on the same network
May 28, 2009 | HP PSC 1410v All-in-One Printer
Printer/ 3500 - 4500 instruction manual & cd
my prob is that it only prints one page of my document
Jan 01, 2008 | Intel NetportExpress PRO/100 Print Server
Documents not printing
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
HP Color LaserJet 2600n Printer Logo
100 people viewed this question
Seeker5211
Seeker5211
