Question about Canon PowerShot S3 IS Digital Camera
My camera will turn on, but I only see black through the visor. If I take a picture, the resulting image will be black. That occur on any mode I select
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture.
You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Jul 17, 2009
Visor view
Some of ALPHA DLSR are prone to have such problems on antishake mechanicsm. I stucks and fails. You start to see a black line or twisted view instead to correct image seen on optical visor. You either need somebody to service it or you need to remove ccd board and fix the shaking mechanism by trial and error. Fixing means really fixing it to surface that it wont move anymore. Since this will allow framing corect you will loose anti shake function. though situation. Check the link. you are not alone.
a200 sensor shake stabilization malfunction dropped camera
Apr 02, 2014 | Sony Alpha DSLR-A200 Digital Camera
Lines appear in picture
Sound like a problem with the CCD sensor; this isn't a job that you could solve yourself. Some symptoms of a defective CCD (Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value.
If this defect occurs, the signal is not output from the CCD correctly when in shooting mode, which results in symptoms like the following in captured images. These symptoms can be confirmed on the LCD monitor. The same symptoms may also occur in recorded images.
* images do not appear
* images appear distorted
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Sony service. I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Good luck.
Sep 16, 2011 | Sony Cameras
When i take a picture a pink/white blob in the centre occurs. If i point the camera at a bright light and take some photos this dissapears, but if i dont take a photo for a few minuets it comes back. This...
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
The Malfunction:
Among the CCDs used in the affected products listed above, it has been confirmed that, especially under high-temperature/high-humidity environments, the internal wiring may come undone in some places.
Additionally, cpould read this article about recall and solve for free (not allways): Cameras-With-Defective-CCDs-Can-Be-Fixed-For-Free
Hope this helps.
Jun 25, 2011 | Fuji FinePix S20 Pro Digital Camera
My camera has been working fine. Had it in my purse over the weekend, took it out to take pictures. When I turned it on, I have this cone shaped image in the middle of the screen that has a red line...
When you take one pic, this lines appears in the image? Some symptoms of a defective CCD (Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
Jun 22, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
All of a sudden, my pictures have a pink splotch running vertically across the center of the picture. This is happening more often than not, and I can also see the splotch on the image display when I am...
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card. A problem has been discovered in some of the CCDs used in Panasonic, Fuji, Sony and Canon digital camera and digital video camera products that causes images to appear distorted or not to appear at all. And the says apologize for the considerable inconvenience this represents for your customers. Along with our respectful apology, we would like to advise our customers of the details of this issue and our policy for handling it, which are as follows.
The Malfunction:
If this defect occurs, the signal is not output from the CCD correctly when in shooting mode, which results in symptoms like the following in captured images. These symptoms can be confirmed on the LCD monitor. The same symptoms may also occur in recorded images:
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; this, isn't a good new, but hope helps to solve it.
Jun 14, 2011 | Panasonic Cameras
Canon S3 IS , the display is black, icons are fine. Both in the visor or in the 2'' display ????
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jan 10, 2011 | Canon PowerShot S3 IS Digital Camera
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Jul 13, 2009 | Olympus FE-230 Digital Camera
No image on Cybershot DSC-T1
It is known problem of bad ccd imager in Sony DSC-T1 Cyebershot camera and ccd imager will be replaced.
Sony will repair this camera free of cost for ccd imager problem as per announced scheme. You will be charged $20 for shipment.
Click Sony CCD Imager Support fro details.
Apr 12, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Black display
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 25, 2008 | Canon PowerShot A80 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
