Question about Acer Aspire One PC Notebook
I have an SW-E700 machine i can get access to the internet via wi-fi but when i try to open an internet page i get an error message server not found? any idea why.
Tip
How to find a wireless password for my iPod Touch
<p>If you try to access the Internet to your iPod Touch, Wi-Fi hotspot and only that will detect the device is marked with a padlock, which means you need a password to use Join the network type. Ipod touch internet access via Wi-Fi, allowing you to browse websites with the Safari application, check your e-mail and free video calls with Face Time app. You need someone for the password if you want a Wi-Fi closed. <br /> <p><br /> <p>1. Ask your department manager of the company computer network password for the Wi-Fi when you use your iPod Touch to access the Internet while at work. <br /> <p><br /> <p>2. Check the password for a printed receipt to a Wi-Fi closed after making a purchase of a restaurant that offers Wi-Fi service to paying customers. <br /> <p><br /> <p>3. Ask your neighbor for permission to your WiFi signal, if you want to access the Internet via Wi-Fi network from your computer. If you are on friendly terms, she would give him the password. <br /> <p><br /> <p>4. Go to decree or in a mall and ask for the password to block Wi-Fi, so you can access the Internet while you shop. <br />
on Jul 21, 2011 | Computers & Internet
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
Usb arrow itunes error
iTunes for Windows iTunes can contact the iPhone iPad or iPod software...
If you can access your device's settings menu and connect to Wi-Fi, install the latest version of iOS over Wi-Fi using Settings > General > Software Update. If your device is locked with a forgotten passcode or in recovery mode, you will need iTunes to restore the device.
If one of the alert messages above appears when you try to update or restore your iOS device, connect to the Internet with your preferred web browser, and access the iTunes Store.
If you cannot connect to the Internet with your web browser
If you can connect to the Internet, but see an error when accessing the iTunes Store
If the iTunes Store shows a blank white page
If the iTunes Store opens successfully
May 05, 2014 | Apple iPhone 3G
My laptop and HP Deskjet 3510 All-in-one printer are on wi-fi networked to my wi-fi router. My problem is that when my laptop is connected to the internet my laptop is not able to communicate with my HP...
Okay... Sound to me like the DHCP Server in your router is off..
Well, do this or have your technician login to your Router admin page ( by typing 192.168.0.1 or 192.168.1.1, (or something similar depending on the brand and make of the router) into your browser and hitting enter) and either make sure Lan side DHCP server is on, or leave it off and just assign different static local IP's to each of your network devices ( e.g. 192.168.1.10 for you laptop and 192.168.1.11 for your printer). I think that will solve your problem if its related to an IP conflict.
Hope this Solves your problem. :)
Jan 07, 2014 | HP Deskjet 3510 e-All-in-One Printer
Panasonic viera tv. Connection error 007
My TV set is PANASONIC VIERA 32AS600 series. Received error 007, canot connect to wi-fi network. In wi-fi settings, change to MANUAL, check proxy settings: delete all letters/characters in proxy address (leave blank), proxy port is not critical. Check your connection. Good luck !
Jul 30, 2012 | Panasonic Televison & Video
Always cannot find the srever at yahoomail
This may be due to a number of reasons:
(a) if yahoo mail is your home page & you're using wi-fi, then your browser (Internet Explorer? Safari? Mozilla Firefox?) may return the error message "Cannot find Server" when the wi-fi link has poor (or no) connectivity.
(b) the Yahoo mail server may actually be down
(c) there may be a typo in the URL (universal resource locator) you're using - even a single mistaken character will cause this error.
(d) there may be a cut in the internet between your computer
and the Yahoo mail server, but the nameserver still has the server's IP address in its table.
(e) about 1000 other reasons.
Sep 12, 2011 | Computers & Internet
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
I am getting error code 85020 on my nintendo Wii console
This is a fun wi-fi networking thing. Usually means the nintendo server is down due to server overload and you have to wait it out. On the bright side, they are working to resolve this issue terminatedly. So hopefully you wont be seing this in the near future.
For now just try later and eventually it will go away.
Dec 05, 2009 | Nintendo Wii Console
Wii Error Code 91010.
Error Code: 91010
Our experience shows that error messages within this range are typically caused by temporary network issues with the Nintendo Wi-Fi Connection. If there is a problem with the network, our technicians will work to get the service back up as soon as possible. Please retry your connection later.
If you are connecting to the Nintendo Wi-Fi Connection for the first time, or the problem has not resolved itself after a few hours, please review the following:
  1. Our servers may be trying to handle an unusually high amount of traffic (especially if you are trying to play online with a recently-released or popular game, or if there is a new Wii system update). Please wait a few hours and try the connection again later.
  2. How are you connecting online? The Nintendo Wi-Fi Connection is only compatible with Cable, DSL, and Fiber-optic internet connections. If you are connecting via Satellite, EV-DO (cellular), Dial-up, or other types of connections, then you should try to use an alternate type of connection. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  3. The error may be caused by a basic setting on the router that needs to be adjusted (such as the channel). Please review our general router troubleshooting.
Sep 12, 2008 | Video Game Consoles & Games
Acer Aspire One  PC Notebook Logo
209 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
