Question about Dell Vostro A860 Notebook
Laptop switch broken !?!?!
On my laptop the bluetooth switch on the front is broken and i want to know if i can turn it on without using the switch..
thanks x
Acer ferrari 1100 busted bluetooth switch. How do you turn it on?
If it's the external switch that's broken then you'll likely have to disassemble your laptop to flick on the internal switch. If the internal switch is the broken one, then you'll still have to take apart your laptop and replace the broken one. You can probably order a new switch from Acer or you can check ebay to see if anyone is selling a Bluetooth switch for your model of computer. Be sure that you know what you're doing if you're going to do the repair yourself - there are alot of little parts and screws that you are going to have to remember how to put back in their proper place in the end. Another solution to your problem would be to buy a USB Bluetooth adapter. That way you don't have to pay alot to have your Bluetooth repaired.
Mar 22, 2010 | Acer Ferrari 1100 Notebook
How to enable bluetooth on hp pavillion laptop
Hey there,
If your particular model of HP has the bluetooth installed from the factory, turning on the wireless switch on the front left edge of the laptop enables the bluetooth, as well as the wireless LAN. A bluetooth icon should appear in your taskbar, near the clock, when bluetooth is turned on. Most of the cheaper versions of the DV6000 series do not come with the bluetooth module installed. The module can be ordered from HP Parts and installed by the end user, if they have a little computer know how. You would then download and install the bluetooth software pack that is available on HP's support website.
Hope this will help to resolve your issue with Bluethooth..
Cheers!!!!!
Vivek
Feb 14, 2010 | Computers & Internet
My Laptop's Bluetooth Won't Turn On. I Push FN + F6 (Which Is To Turn On Bluetooth) And It Doesn't Work. It Just Keeps Telling Me Bluetooth Off. My System Information Says This Driver Is Off. Any Help...
Which model laptop is this? Many of the Gateway laptops have 2 switches for the Bluetooth. There is a physical switch on the front or side of the system that needs to be turned on for both the wireless LAN and the Bluetooth to work.
The physical switch needs to be in the ON position, then you can use the FN-F6 to toggle the bluetooth specifically on and off. Depending on the model there will be another toggle, possible FN-F2 to toggle the wireless Lan on and off once the switch is turned on.
Dec 29, 2009 | Gateway Notebook PC - Mobile AMD Athlon...
Bluetooth problem in lenovo 3000 G430 laptop
i am using lenovo 3000 g430, and i am fall in problem about bluetooth,
i am already install xp and vista, but when i install the bluetooth driver
one warning message show me "bluetooth device not detected"
my bluetooth device switch is on but indicator led light still off,
please help me , how can i use bluetooth in this laptop.
Dec 13, 2009 | Lenovo 3000 Y410 Notebook
How do I enable bluetooth in my Acer Extensa 4420-5963
Actually Acer use the same laptop case for some of their models, so the acer 4420 doesn´t have built-in bluetooth, you won´t find any driver for the bluetooth cause that reason. I have an extensa 4420-5910, have a bluetooth switch in the case but no bluetooth, if you check at Acer´s web page it say thet some models doesn´t have built-in bluetooth but the switch is in the laptop case... On the other hand, if you install an external bluetooth device, the case switch will be usefull to turn it on and off.
Mar 13, 2009 | Acer Computers & Internet
Won't connect to bluetooth printer
Sir,
This laptop does not ship with a bluetooth device. The button is available on the casing because Acer do not have separate casings for laptops without Bluetooth. Also, an opton for adding a bluettooth chip is available with Acer at a cost though.
Mar 02, 2009 | Acer TravelMate 4200 Notebook
Laptop wlan and bluetooth switch broke help? plz!
The answer is probably no. If it was stuck in the on position you could disable it some other way but stuck in the off position is different.
If you are using Vista you can open the windows mobility center and look at the wireless section. If turn on is grayed out then mess with the place the switch should be until it is not grayed out.
Her is a link for acer parts
http://www.excelcomputerinc.com/html/xlsearchbrandresults.asp?brand=acer#link5
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
Hi my laptop (acer aspire 5672wlmi) wlan and bluetooth switch that are conntected to its motherboard have broken off and are broke is there any way that im able to turn the bluetooh and wireless on without...
I believe that you can turn these functions on and off via the Network Connections that you can access from the control panel.
In Windows XP:
Click on START button
Select Control Panel
Click on Network Connections
In Windows Vista:
Select Network and Internet
Select Network and Sharing Center
In left panel, select Manage Network Connections
Once here, you should see your wireless adapter and your bluetooth adapter. If you Right-Click on either connection, a menu will pop up and you can choose to Enable or Disable the connection without the button on the front of your computer.
Hope this helps.
Bluetooth
Assuming your machine has bluetooth installed, and the driver is installed, you also cannot have "fast user switching" on and use bluetooth. As for turning bluetooth on, there is a button, usually on the lcd bezel, I'm not sure on this model, which has to manually be turned on. Hope this helps. Good luck
Aug 31, 2007 | Toshiba P25-S520 Notebook
Dell Vostro A860 Notebook Logo
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
