I have a LG50PT350 Plasma TV. It recently went into blotchy black and then into completely black with no picture but did have sound. I replaced the y and z buffer boards and the y sustain board as recommended but all parts are of a used tv with broken screen. I tested the y and z buffer boards seem to be fine. Not sure how to test the y sustain board but replaced it as well. Tested all fuses. All tested fine. What else could possibly be the problem if not those that I have replaced? I'm at a loss here. Could it be possible the replacement y sustain board is bad too? How do I test that? Any advice would be greatly appreciated.
If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Testimonial: "Thank you so much!! Done some research on the site you provided. Very interesting, gave me other ideas and led me elsewhere in my searches. Although unlikely but does happen can be the main logic board or the logic/address buffer boards. Just ordered the main logic board to start. Will see in a few days. If not then can onto the logic/address buffer boards. If still not working been quite an informative interesting experience. Thank you again."
