Question about Toshiba 43H71 43" Rear Projection Television
43H71 I pulled a owners manual off the toshiba web site,but need to find theschematic or service manual in order to replace the bad parts.Wherecan i get it?
  • 205 Answers
If you're talking about the STK392-100 convergence amps, the repair manual is not a great deal of help.
Here are two websites I found helpful:
http://www.repairhelper.com/tv_board_detail.asp?identity=3809
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Good luck.
Posted on Nov 18, 2007
Support toshiba.com
It is on web site , go to toshiba tech dept. you can not order , down load.only
Jan 09, 2013 | Toshiba Satellite P105-S6227 Notebook
I have a 43h71 Toshiba that does not have a picture. The red power light is flashing. Any idea what this means?
pam4402,
Most manufacturers today have taken advantage of the diagnostics available when circuits fail. Your flashing light indicates generally where the problem is. This is disigned to help us technicians find the problem easier and faster. You did not mention the number of blinks. Toshiba is secretive with their error codes. You would need to buy a service manual from http://www.servicemanuals.net to obtain them. Cost is about $16.00 US for a download. This would provide the information that you need.
Thanks for using FixYa and for the great rating. Please consider a testimonial.
hardrocko
Jan 08, 2011 | Toshiba 43H71 43" Rear Projection...
43h71 service manual
What is proiblem with your set?
Oct 09, 2008 | Toshiba 43H71 43" Rear Projection...
Toshiba Model #43H71
go to service mans menu and try horiz width adj..
Sep 22, 2008 | Toshiba 43H71 43" Rear Projection...
Problem with tv
If your Model is Tosh 43H71,then pull chassis and locate F850,
F851 soldered-in fuses...check with meter..if open,replace with
proper value micro fuse(s) and solder jumper wires 008,010,017,
048,600 located on signal board.Replace convergence IC's
STK392-110 with IC's from kit # X 480295 ( upgrade )...........T.
Mar 31, 2008 | Toshiba 43H71 43" Rear Projection...
Motorola A1200 Flip Damaged
Your in luck! www.cnn.cn you can get full housings and replacement hinge springs for this model phone. Im not sure which parts exactly are broken on yours, but you can get any of the case pieces from that web site. I personally have ordered from there before and have been satisfied.
As far as the repair manual, no, there are none available to consumers that im aware of.
Need anymore help let me know!
Jan 13, 2008 | Motorola Mobility MOTOMING A1200...
Toshiba 43H71
Hi, I am having the same exact problem. Finally found this. I ordered the parts and will be performing this when they get in. http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
May 11, 2007 | Toshiba 43H71 43" Rear Projection...
How to adjust red blue green
if ur in service mode already..turn down all drive.green first turn it up until the desired intensity is achieve.then blue all the way until it almost blend the green.u must not see one color either too much green or blue.turn up red now,let it blend until u see a perfect black and white.note:make sure that the color level is set to minimum and tint to center. ihope i help u..
Mar 20, 2007 | Toshiba 43H71 43" Rear Projection...
Toshiba 43H71 43" Rear Projection Television Logo
249 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
