I was looking for the setting for the fuel air mixture screw for the bolens 31 cc 2 cycle cultivator
From the factory, when everything was new, the Hi and Lo screws were 1 1/4 turns out. As things wear and as fuel forms deposits in the carb, you may have to adjust the screws out further. Usually Lo gets stopped up a little first. Lo side adjustment effects how the engine goes from idle to upper speeds. Hi side only effects the engine at wide open throttle. If you have to go more than 2 1/2 turns out on either screw, then a carb overhaul or replacement is in order.
