Question about Baby Lock Ellure
Ellure product manual
I am trying to find my manual and can't my bottom thread (Bobbin) it bleeding through the top thread, I can' seem to get it adjusted correctly with my manual. Any help would be appreciated.
  • Anonymous Nov 20, 2007
    I just bought a new babylock ellegante 2. The great deal of the bobbin thread is showing on the top. What do I do.
  • 4 Answers
That machine comes with a pink dot auxilary bobbin case with a pink dot. This bobbin case has an additional gram pull of 7-9 grams, for use of bobbin thread other than the finishing touch brand that is suggested for this model. You can also go to page 4 of the control setting page and reduce the default the embroidery tension setting.
Posted on Nov 26, 2007
WHAT DO I DO TO GET MY BABY LOCK ELLURE ESL TO PICK UP THE BOBBIN THREAD?
You have your bobbin inserted into the machine spinning in the wrong direction. take the bobbin out and flip it over and wind around needle plate guide and cut. Look at the little pictogram on the plastic part of the machines throat plate. It shows which direction the thread should spin off the spool when you drop the top loading bobbin into the bobbin case.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 30, 2014 | Baby Lock Ellure
I can't understand the manual's directions on how to adjust the tension on the bottom and my bobbin thread is coming to the right side of the fabric.
Make sure the bobbin turns anti clockwise in the bobbin case, adjust the screw clockwise a quarter of a turn at a time until you can just pull the thread through with slight resistence, top tension about 4 or 5
Oct 20, 2013 | Baby Lock Ellure
My machine will sew one or two stitches then the threads get all tangled under the plate. appears to be the top thread, not the bobbin
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 20, 2013 | Baby Lock Ellure
I have a ellure baby lock sewing machine. It will sew fine for a while and then the bobbin tread gets tangled up and breaks the needle thread. What should I do?
first change the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is not warped or damaged
make sure the bobbin is not to full
make sure the bobbin is inserted correctly & turned correctly in the
bobbin case
make sure there are not any burrs on the needle plate
make sure there are not any burrs on the bobbin case
Jul 09, 2012 | Baby Lock Ellure
Bobbin thread is coming to the top of the embroidery project
Refer to the manual for cleaning the bobbin case and surrounding area.
Re-thread and replace the bobbin. Be sure to use machine embroidery bobbin thread. I use NEB prewounds.
Try a different design and use a cut away stabilizer. This holds the stitches better than tear away.
If the stitching is as before, lower the tension setting.
If you cannot resolve this, it could be a timing issue. Try the sewing feature to see if the stitching is off. If so, the machine will need to go in for service - take samples with you.
Mar 28, 2010 | Baby Lock Ellure
The bottom thread gets all knotted up when I sew... everything locks up and there is a mess of thread on the underside of what I'm trying to sew. help?
The tension in the top thread is controlled by a dial, and the tension in the bottom thread is controlled by a small screw on a spring on the bobbin. The tensions are supposed to be exactly equal in order to make the stitch perfectly in the middle of the cloth. Uneven tension will pull the stitch up or down from there. You can tug on each thread to feel how much tension there is. Often the bottom will get too much tension by just inserting the bobbin upside down. Leave the bobbin door open, and watch the operation. The top thread is pulled down around the bobbin. See if it is getting caught on anything?
Dec 18, 2009 | Singer 3116 Simple
I am embroidering and my machine is picking up the bobbin thread and it is appearing on the front of my project and also on the bottom of the design
Make sure that the bobbin thread is in the bobbin case tension. If you are using special "bobbin thread" it may be a lighter weight thread than the top thread.
Turn the upper tension to a lower number.
Make sure that you have adequate stabilizer and the appropriate type.
Jun 27, 2009 | Baby Lock Ellure
Babylock Ellure thread issues
I have the same machine and love it. Sometimes if the thread is old that will happen to me.  And also I spray the thread with static guard before i thread the machine in dry cold weather.  Since you said you are an embroiderer I assume you are using the same weight thread top and bottom. The other thing that causes that on my machine is if there is a nick on the spool of thread I am using and the thread catches just a little as it comes off the spool.  I use a fine nail file and smooth off the edge where the little v is to reattach the thread when you are finish using it.  I never use them. You do sew a little and cut off the tail off the top thread before you let it go through the rest of design. I hope you have found the solution but I learned these tricks while having the same problem as you.
Jan 25, 2009 | Baby Lock Ellure
Thread problem
I'm not sure which thread you are referring to, its either the bobbin thread (under) or the needle thread (above.top)
I'm sure you can find some helpful advise here on the baby lock site
http://www.babylock.com/support/faq/?FAQ=10
Jan 24, 2009 | Baby Lock Ellure
Thread is knotting up
You probably are in need of a new bobbin case they are plastic and oif you have broken a needle lately it may have gouged the case and the top thread is getting caught and bunching up underneath. Visit www.stevessewandvac.com you can contact them and have a bobbin case sent to you.
Mar 13, 2008 | Baby Lock Ellure
Sewing Machines Logo
149 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
