You must leave the radio ON like this until the SAFE mode clears.
When it does, to get the code accepted, press AS and then a couple of seconds later the 'on' button, together until it beeps.
As you know you will then see 4 dashes. Each dash is a number from your code.
Use the numbers along the radio (1 is first number in code, 2,3 and 4 the other numbers and so on)
As an example, if your code was 4432
press button '1' 4 times (gives a 4)
button '2' 4 times (gives a 4)
button '3' 3 times (gives a 3)
button '4' 2 times (gives a 2).
When you see your code displayed correctly on the screen press AS until you hear a beep.
HELP Radio SAFE mode
SOURCE: air bag lights come on the dash board , why,opel vivaro van
could be same conection check to see if it hasent come loose some times there is one under passenger seat
SOURCE: after serviceing injector pump for opel vivaro CDTI 1.9 2003
NO START OPEL VIVARO FIX - YouTube
? 3:39
www.youtube.com/watch?v=i_G7Al9IFuU
Jan 21, 2014 - Uploaded by anto denn
All it does is crank but as soon as you fiddle with the injector ...Help have a 2003 trafic drove fine then one day i drove 100 yards and it just ... is the fuel pump turning on when you turn the key ?... Vauxhall Vivaro 2 0 CDTI Turbotune tuning box fitting guide - Duration: 6:40. by Darren Darling 28,094 views.
