Question about Dell Computers & Internet
Can I upgrade my dell latitude C600 40gig primary hd ide pata to a 120 or 160 ide pata
    Problem Solver:
  • 13 Answers
Posted on Jul 17, 2009
  • 400 Answers
You can get a 160gb for it:
http://www.cmsproducts.com/detail.aspx?ID=847
So anything up to 160gb pata should work.
Error Message: Drive 2 not found: Parallel ATA, PATA-0 (PRI IDE MASTER)
Anonymous,
Did you set the jumper on the drive to cable select? Check to what the jumpers on the back of the drive is set to. You should have 3 selections. primary,secondary and cable select.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 21, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
Hi . I have trouble with Dell optiplex GX280 . In the PATA I have two devices . DVD and HD . Both set with jumper . DVD as Slave and HDD as Master ....But the install os cannot detect HDD . where is...
I don't know where the trouble is without more information.
Some tips/information I will list, however,
1) The master harddrive that came with the computer, and has the operating system on it, is a SATA unit.
Therefore any harddrive installed along with it has to be installed as a Slave drive.
BIOS will look for the harddrive with the operating system on it. This harddrive has to be set as a Master drive. (Primary Drive in BIOS)
Installing a harddrive that is a PATA (IDE) unit, AND a PATA optical drive on the same flat ribbon cable, has to be done accordingly;
A) It depends on what flat ribbon cable you have.
There is a 40 wire cable with a 40 pin connector. (39 actually. One socket hole is not used)
There is an 80 wire cable with a 40 pin connector. (39 actually)
http://en.wikipedia.org/wiki/File:ATA_cables.jpg
http://en.wikipedia.org/wiki/Parallel_ATA#IDE_and_ATA-1
Proper method of connecting,
http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
2) Proper method of using jumpers on an IDE (PATA) harddrive, and connecting the flat ribbon cable,
http://www.youtube.com/watch?v=4inX3nC6M1E
Regards,
joecoolvette
Jun 05, 2011 | Dell Optiplex GX280 (99301) Motherboard
How do I replace the hard drive on a Dell Latitude d610?
mostally on bottem acces for hd open with 4 screws and take out the drive and replace it for a bigger or for the same look out by buying hd for the same hight and idee or sata
Sep 28, 2009 | Dell Latitude D600 Notebook
Setint the jamper as a 2nd drive and Do i need to farmat it frist
If I recall right this HDD is a PATA (IDE) type. As for the Jumpers please check the following link. The jumper should be as Slave drive.
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
May 15, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Dell 8400 e210882 .hd on ide pri .error initializing pci express nic bridge. drive 0 not found. drive 5 not found.the hd is seen on drive 4,and tests ok.flop. and cd rom off in bios. where do i put ide...
When installing hard drive much sure that the jumpers are set to primary position or ds master on some drives. Make sure they don't conflict with other drive or cd rom.
Now if having issue with bios error download the lastest bios update and run it. If not sure ask a friend who has do it before and get some help. The error sounds like a bios upgrade is required to solve problem. Let me know how you go.
Mar 19, 2009 | Dell (E210882) Motherboard
Internal HD cabling
I understood your problem there are two different connectors
SATA:
And PATA:
If your computer has IDE (PATA) connectors you need an adapter like this one:
Native SATA Drive to IDE 40-pin Adapter for Most Enclosures
Jul 31, 2008 | Adapters.com Video to Monitor HD-15...
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Can i Install PATA hdd on Dimension 4700
I'm sorry, but I couldn't wade through this bunch responses, so I'm going to give you my own.
You have 2 sata drives installed, already, so you cannot add an additional one w/o a bunch of wonky adapters, so use the IDE channel. You say you have an IDE rom drive. Well, there's a reason there are 3 connections on an IDE cable. One side goes into the motherboard, the other 2 into your drives. The motherboard side is the one furthest away from the center connector. I assume you have the primary connector connected to your rom drive. the 2ndary one would be on your hdd. Why people asked you why you're doing this is beyond me. It works, you'll have an extra drive, your preference. Whatever.
Let me know if you have any more inquiries.
To answer your questions from your original post directly, the other 'ide' channel is specifically for a floppy disk You CANNOT connect an IDE cable to it. And yes, you can connect an  hdd to the slave port on the ide cable.
Jan 23, 2008 | Dell Dimension 4700 PC Desktop
Sata vs ide
install the SATA drive in first and install your XP operating system on that one.
Then after thats all set up and running install the PATA drive.
Please let me know how you make out
thanks,
Dec 26, 2007 | Computers & Internet
Computers & Internet Logo
117 people viewed this question
Alun Cox
